Corbeau Seats?
Old Mar 24, 2009 | 08:24 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Default Corbeau Seats?
I have been thinking I need to get some. I am leaning toward the Forza and am wondering if any members have these, have pics of these installed, or any mounting issues with these? Any help would be great. Thx in advance.
Old Mar 24, 2009 | 08:40 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
a fellow forum member has the Corbeau A4 in micro suede with harnesses. super nice seats!!! i'd buy them but i bought some caravaggios instead...
aj
Old Mar 25, 2009 | 09:32 AM
c5blkvetteguy
Anyone else?
Old Mar 25, 2009 | 09:43 AM
WKMCD's Avatar
WKMCD
I have Corbeau A4's in leather. I don't track the car and comfort and support are important to me. Not a good idea to run harnesses in a vert.
Old Mar 25, 2009 | 10:10 AM
Indy's Avatar
Indy
Mounting ideas:
Here's the passenger side fixed bracket:
mounted:
driver side with slider:
cheers
Old May 29, 2009 | 10:34 AM
2MCHPWR's Avatar
2MCHPWR
I have the forza's in wide version with leather/vinyl/leatherette? and sliders if anyone was interested in buyin them, shoot me a PM.
Old May 29, 2009 | 10:40 AM
GETOPLES's Avatar
GETOPLES
Just wondering what factors you considered when selecting that particular model of seat from Corbeau?
Old May 29, 2009 | 10:44 AM
2MCHPWR's Avatar
2MCHPWR
they were in the car i just bought.
Old May 29, 2009 | 12:17 PM
Indy's Avatar
Indy
The Forza seats are not adjustable, but very comfortable....I find them a lot better to sit in than the stock seats and they have soooooo much better lateral support.
Cheers, Indy.
Old May 29, 2009 | 01:08 PM
digivex's Avatar
digivex
Last weekend I installed some A4s in my C5. These are Corbeau A4 Black & Grey Microsuede Racing Seats, slotted for submarine belts, with double locking slider mounts.
I installed these because tech was giving me a hard time about not having a slot for my submarine belt. So, I added the slot to the seat order. I already have a Simpson Camlock black 5-point harness installed on the driver's side.
About the install…
The first attempt to install did not go well. The seat recliner mechanism did not fit against the stock C5 seat belt mechanism (down near the floor, towards the rear of the door). So, to accommodate that, I reversed the seats, placing the seat recline mechanism inside, next to the tunnel. This makes for a very tight fit to get your hand down to adjust the seat, but it fits.
The A4s are wider than stock where the roll bar comes down next to the door. Therefore, my side roll bar presses against the seat and will eventually wear it down. It makes it a bit difficult to lock the roll bar in place (it uses a pin). So, this is something I will have to live with.
And, once done with the seat swap, I found that my telescopic steering wheel control no longer worked. I have to assume that this is tied into the stock seat electronics / memory and, with the stock seats removed, it stopped working. Luckily, I had it in the position I use and rarely use telescopic wheel. I’m sure that if I did some research I could find a way to wire it to work.
About the color: Although they are called “black/grey”… They are closer to black/white and I’m a bit worried they will stain easily. So, I coated them in Scotch Guard, hoping that will prevent some stains.
Now they are in and I’ll pass through tech without an issue. They look good (still brand new of course) – And, I like adding some color to my all black interior. They are also very comfortable and hold you in place.
So, although this sounds more negative than positive, for my purposes, I found the A4s to be a decent solution, within my budget and a nice interior upgrade.
Old May 29, 2009 | 02:44 PM
montac's Avatar
montac
I have a set of Arizen Racing Seats (Forum Vendor). They are supportive, comfortable, and high quality. It also helps that they are around the block from me. Mark at Arizen just became a vendor here and also has new seat offerings that are much like the Corbeau and Sparco's but I feel he uses higher quality material to cover his seats.
http://forums.corvetteforum.com/nort...ats-in-ct.html
Charlie
To Corbeau Seats?
