headlights are going nuts!
Old Mar 25, 2009 | 12:52 PM
2003 electronblue's Avatar
2003 electronblue
Default headlights are going nuts!
anyone ever experince there headlights go up and down? one goes up while the other goes down then when closing them the left headlight goes up and down 6 times before it closes for good...whats the problem?
Old Mar 25, 2009 | 01:50 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The headlight door motor is connected to the headlight via a lifting arm. There is a 10mm nut that holds the lifting arm to the motor. If this nut is not tight enough, the arm will not hit the limiters and continue to move up and down.
Old Mar 25, 2009 | 03:13 PM
2003 electronblue
thankyou very much! the nut was very lose about to fall off, i was able to tighten it enough to get the arm working again i will need to buy another packet of little wrenchs..you saved me a day at the dealership!
Old Mar 25, 2009 | 06:07 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you're welcome. You may want to install a spring-style lock washer to keep it from backing off again.
To headlights are going nuts!
