Anyone had this problem?
Old Mar 26, 2009 | 12:34 PM
justin_heat05's Avatar
justin_heat05
Default Anyone had this problem?
When I raise my headlights, the doors rub a spot on my hood on the inner corners. Anyone encountered this and is there an adjustment for this?
Old Mar 26, 2009 | 12:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
there are 4 Torx screws you can use to adjust the covers...you need to remove the black bezel (3 phillips screws) to see the side Torx screws..you will need to have the lights closed to loosen the rear Torx screws...overall there is alot of play to make adjustments just be careful to get everything as flush as possible on all sides before final tightening
Old Mar 26, 2009 | 12:41 PM
justin_heat05
its pretty flush, it only rubs when its raised.
Old Mar 26, 2009 | 01:44 PM
Gideon's_Test's Avatar
Gideon's_Test
Mine was like this when I bought it. It's torch red and it had rubbed so much that it was yellow (must be the color of the unpainted plastic?). Glad to see instructions for adjustment.
To Anyone had this problem?
