Rear Marker Light?
Old Mar 27, 2009 | 02:09 PM
RusherRacing's Avatar
RusherRacing
Default Rear Marker Light?
I was pulling out my rear marker lights last night and noticed both the studs on the front of the lights were broke off. While I was pulling the rear nut off on one side the rear stud broke off.
So my question is can I use 3M tape to put them back on the car? Has any one used this method before?
I am taking them in to be smoked at a local shop. Just wondring if I should buy new ones or just have these smoked and use the 3M tape?
Old Mar 27, 2009 | 02:13 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would buy new ones, They don't cost that much if you do a search.
Bill
Old Mar 27, 2009 | 05:12 PM
RusherRacing
Called my parts guy and I have some coming in.
They don't cost much thats for sure. Might run a die over the plastic stud so i can put a regular nut on it.
Old Mar 27, 2009 | 08:19 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I thought about cutting a section of vacuum line to slide over the studs. It should hold and would be easy to remove.
To Rear Marker Light?
