Body Side Molding Removal
Thanks.
B
here is my post, pm me if you have any questions...
i used 3M adhesive remover, safe for the paint
Anyways...I read all your helpful tips and did it right after reading. I have one alteration to the fishing line tip - which is good - but only needed to get it started a few inches.
I found that after you heat up several inches, cut it with the fishing line, and can get an clean, soft rag under the starting edge, all you need to do is apply slight lift pressure as it heats, to remove the rest of the strip. Heat a minute, pull...heat up, pull...heat up, pull....and so on. The tape will separate and leave half the residue behind. (And it's only a top/bottom tape job - not solid coverage underneath.) So as you are pulling, aim the heat inside the gap under the BSM, so it warms top and bottom at the same time evenly, before adding lift pressure. This allows you to use the BSM for leverage, but STILL be patient and only pull a couple inches at a time until you can heat some more.
Then use a nice soft glove (I had a clean pair of leather gardening gloves) and "roll" the remaining tape off the car with slight pressure. All you will have remaining then, is a slight edge residue of dirt with maybe a tiny bit of strip adhesive.
For a cleaner, I used the same GOOF OFF HD that I just used to clean my air bag cover to newness (another great thread), and wiped it with a clean rag, letting the GOOF OFF HD do its thing with little to no pressure.
Finally, wash off the strip area with some gentle soapy water, rinse and wax the strip for new protection.
Viola!
Done and beautiful. One side only took me about 30 minutes.
I'm with you, bro. Don't have any problem with them, personally. To each his own, I guess.
