Replacing skid bar assy.
Old Mar 29, 2009 | 04:35 PM
orangecrush08's Avatar
orangecrush08
Default Replacing skid bar assy.
Have any of you replaced your radiator support/skid bar cage? I ordered the assy. and thread inserts from Gene at GM partshouse, but am curious what is needed to install them in the framework before I get started raising the car to start replacement. As I'm disabled it takes more planning doing tasks I used to jump right into.
Old Mar 29, 2009 | 09:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There's a tool needed to install the threaded inserts.
You'll have to pull the front fascia and support the radiator.
There are four bolts that hold the cradle to the frame.
Old Mar 29, 2009 | 11:40 PM
zombywuf's Avatar
zombywuf
Check out this link:
http://www.digitalcorvettes.com/foru...d.php?t=117739
It should help a lot.
To Replacing skid bar assy.
