Do any upgraded calipers clear CCW505a's?
I've got 19" CCW 505a's on the front of my car. Are there any 4 piston or 6 piston calipers out there that will clear without spacers?
1 Post
St. Jude Donor '08
Try looking at SSBC. Here is a link.
http://www.ssbrakes.com/commerce/det....cfm?nPID=8844
Might also try Wilwood. I know they sell some of their 4 and 6 piston calipers in a "thinner" size to fit some rims. Not sure if they will work for your situation though.
Here is a Pic of my Rear with the Baer Eradispeed +2 14 rears.
Not sure about the CCW's, but I run an 18/19 C6 QX1 wheel with the Wilwood 6/4 and they clear. I would assume a 19 front will clear, but mine clear barely, so you never know until you see it first hand to know for sure. Wheel spoke design/dimensions can still prevent caliper clearance no matter the bigger wheel size.
You might want to call John at CCW to see if he knows any brake setups that might work for your wheel. He is in the business to know, and I'll bet he has some good info.
Toque
