2000 vette remote for keyless entry
Mar 30, 2009 | 09:10 PM
Cruising
the remote for keyless entry does not work. i used the owners manual to try and "match" (learning the remote) the remote and it did not work.
I also tried to synchronize the remote by pressing unlock and lock simultaneously until I heard the horn chirp and that also did not work.
any ideas as to how I can fix this? any ideas as to what may be wrong?
Mar 30, 2009 | 09:15 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Did you replace the battery before trying to sync it to the car?
Mar 30, 2009 | 09:21 PM
Cruising
yes I replaced the battery
Mar 31, 2009 | 12:48 PM
If you haven't replaced the battery, try that. If you have, then the remote may need replacement. They do wear out over time.
Mar 31, 2009 | 12:51 PM
The 2000 remote is a one year part #, you can not use the 97/99 or 2001/2004. Check with Gene his prices are the best. Bill
Mar 31, 2009 | 04:34 PM
Do a search for treads on the forum. a couple of weeks ago someone posted a fix for the key fobs that stop working. It involves a loose chip inside the fob.
Apr 2, 2009 | 02:11 PM
Quote:
Originally Posted by
HarryO
Do you have a link? I am having trouble finding that. I tried searching on some different terms but came up with nada.
Apr 2, 2009 | 02:24 PM
2004 ,
c5 ,
corvette ,
entry ,
fixing ,
key ,
keyless ,
learning ,
problems ,
program ,
remote ,
reset ,
sync ,
syncronizing
