2000 vette squeking noise
Old Mar 30, 2009 | 09:18 PM
mike85's Avatar
mike85
Cruising
Default 2000 vette squeking noise
while driving slowly around city streets the vette squeeks. how can i fix this?
Old Mar 30, 2009 | 09:30 PM
spdracr39's Avatar
spdracr39
Is it engine related, suspension related, or wheels squeaking? Mine squeaks frrom the front wheels and I think it may be the wheel bearings but can't really narrow it down.
Old Mar 30, 2009 | 09:34 PM
mike85's Avatar
mike85
Cruising
sounds like suspension squeeking but what would I need to lube u
Old Mar 30, 2009 | 09:39 PM
SJPD's Avatar
SJPD
lube the sway bar bushings and see if that cures it
lithium grease works good
Old Mar 30, 2009 | 09:41 PM
mike85's Avatar
mike85
Cruising
thanks I will try that
Old Mar 30, 2009 | 10:20 PM
AIKMAN8's Avatar
AIKMAN8
WD-40 the top bushings of the shocks, this will do it! Did for me, good luck...
Old Mar 31, 2009 | 12:22 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
if you have a Z51 option car,,,,they squeak,,,,be proud!
Old Mar 31, 2009 | 07:36 PM
mike85's Avatar
mike85
Cruising
how would I know if the car has the z51 option?...certain number/letter in the VIN?
Old Mar 31, 2009 | 07:40 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Usually, but not always, that sound is coming from the sway bar bushings.
Old Mar 31, 2009 | 08:31 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
Usually after storage the rubber bushings in the suspesion gets hard, use a silicon base on the rubber, then for the upper bushing I use white lithuim, WD40 is good but does dry to a coat sometimes, that will do the trick
Old Mar 31, 2009 | 08:58 PM
mythirdwish's Avatar
mythirdwish
DO NOT DRIVE IT SLOWLY......the worst thing you can do to a vett
Old Mar 31, 2009 | 09:19 PM
bencini231's Avatar
bencini231
To 2000 vette squeking noise
