fob battery?
Old Apr 1, 2009 | 02:03 AM
chazzvette's Avatar
chazzvette
Default fob battery?
Need to replace the dreaded key fob...I think. First I want to try the battery and need to know which one. I know its a 3 volt, but I see there are different numbers. Can anyone tell me what is the correct battery for a `98 fob? Thanks.....
Old Apr 1, 2009 | 02:09 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
The one that's in it should work fine. Just take it with you when you go to buy one.
BTW got a new FOB awhile back from Gene Culley GM Parts, about $60 bucks for my year. He has a sale going on now, I saw a post here today. Lists the year and price if you scan through his sale.....supporting vendor here too
Old Apr 1, 2009 | 02:11 AM
chazzvette's Avatar
chazzvette
The one thats in it just says "3V" on it....no other numbers. Looking at the other batterys, there are three different numbers all are 3 volt.
Old Apr 1, 2009 | 02:15 AM
NOWUCME's Avatar
NOWUCME
Here ya go......if you need the FOB http://forums.corvetteforum.com/c5-g...-specials.html
Best price i found, fairly close to the top of his list of parts. Mine was for a 00' so lucky me, this time.
Old Apr 1, 2009 | 02:20 AM
NOWUCME's Avatar
NOWUCME
I just got a 3v energizer says CR2450 for my old one. Was the right size and would set the FOB but then fob would stop working after awhile so i bought the new fob.....no trouble now. If you hold down the lock & unlock together till you hear a chirp it's supposed to reset it i believe.
I would think any 3v would work if it's the same size that fits. My car is a 2000 and it looks like it is a different FOB, but maybe the same battery.
Old Apr 1, 2009 | 07:14 AM
CR2450 should be the right battery. That's what I bought when I needed to replace mine.
Old Apr 2, 2009 | 04:39 PM
NOWUCME's Avatar
NOWUCME
Just found this link, you might want to check it out.....there is a pic if you scroll down.....might be worth a try. Hadn't seen it before, going to try it on my old fob.
http://forums.corvetteforum.com/c5-t...em-solved.html
Old Apr 3, 2009 | 03:57 PM
MacVette99's Avatar
MacVette99
Unfortunately, a new battery did not solve my key fob issues. I ended up buying a new fob from Gene Culley.
To fob battery?
