Guys, I need your help...........
Old Apr 1, 2009 | 04:04 AM
Gohard777's Avatar
Gohard777
Default Guys, I need your help...........
I know, this is about performance and that's what I want. I got my new wheels, Z06 size, 17x9.5, 18x10.5. I need some tires now. I go to the track about once a year, 2004 Corvette Vert, headers, 373 gears, 2800 stall converter, car won't hook up, couldn't give it any gas until about 100 feet out, ran 12.72 @110mph with a 1.90 60' . with runcraps. Want something better to hook up. But I like to go to the mountains and take the curves so I am scared about Drag Radials. Don't know much about the new ones. Do I get an autocross tire, Drag Radial, or just some street tire with a softer compound? I want some hook up, go high speed and take some curves. what do you guys suggest? Please respond I have to do this soon, it's getting nice out and I've got to drive.....bob.
Old Apr 1, 2009 | 02:53 PM
Gohard777's Avatar
Gohard777
Still need help........
Old Apr 1, 2009 | 03:22 PM
dougbfresh's Avatar
dougbfresh
Get a cheap set of wheels for the track so you can use a drag radial when your there.
Old Apr 1, 2009 | 04:31 PM
poolboy's Avatar
poolboy
Get yourself a setup like this - http://www.z06vette.com/forums/f17/a...-vette-109926/
Old Apr 1, 2009 | 04:44 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
If you're not making a ton of power, a good set of street tires should suit you. Something like a GSD3 or something. Now, I will say that I personally overpowered my GSD3's and went to a Nitto Drag Radial, and other than a little less confidence in wet conditions (and a LOT less confidence in a downpour), my nittos have been QUITE inspiring in the corners I've put them through.
Old Apr 1, 2009 | 05:04 PM
02 C5man's Avatar
02 C5man
I'll take that 1.9 60' time! I've seen a lot of cars with full on slicks get a 1.9.
Old Apr 1, 2009 | 06:19 PM
IMXCITD's Avatar
IMXCITD
yeah...I'd get a second set of cheap rims w/the tires you want for the track.
Old Apr 1, 2009 | 06:22 PM
Z28Johnny's Avatar
Z28Johnny
I like that little trailer idea. It would look a lot better painted with matching Corvette wheels.
Old Apr 1, 2009 | 08:53 PM
angman5's Avatar
angman5
Cheap pair of rims and some drag radials and you will be fine Try MT 305 35 18 DR if you have a 6 speed just don't get crazy when you let the clucth fly try 2500-3000 RPM and you should improve your time a few tents
Old Apr 1, 2009 | 10:19 PM
ZR1991's Avatar
ZR1991
Yep, I was going to suggest another set of wheels, tires. Drag racing requirements are so different from road, I don't know what else you could do.
Old Apr 2, 2009 | 04:13 AM
Something like the GS-D3 tires would be good for the road. As for the track, the suggestion of a spare set of wheel and some drag radials sounds about right.
Old Apr 2, 2009 | 09:33 AM
chaase's Avatar
chaase
St. Jude Donor '12
That is what I do. I use replica z06 front with MT ET Street Radials for the track.
Old Apr 7, 2009 | 01:05 AM
Gohard777's Avatar
Gohard777
Thanks Guys;
I went with the Nitto 555 R2's in 305/35/18 in the back and the Nitto NT-05, 275/40/17 in the front. I'll let you know how it works out. Right now it just snowed in Michigan so I'll do a little more work on the Vette..... Thanks to all......bob.
To Guys, I need your help...........
