[Z06] E85 Z's?
Old Apr 2, 2009 | 01:43 AM
Mr. Furley's Avatar
Mr. Furley
Default E85 Z's?
Anyone running E85?
Old Apr 2, 2009 | 07:57 AM
Ragresen's Avatar
Ragresen
While I am sure with a retune you can Run E85. I am sure there are a few other things you need to change on it like the fuel lines that are rubber. Do not take my word on this in any way though as I am not running it.
Old Apr 2, 2009 | 09:39 AM
James92's Avatar
James92
What is the octane rating of E85???
Old Apr 2, 2009 | 10:24 AM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
While consumers believe E85 is always 85% ethanol, reality is that it's not. Federal regulations mandate 70% to 85% ethanol, however, the Government does not police that and, consequently, quality control is lax. We've seen test data of samples from a few retail sources of E85 in the Midwest that show as low as 64% ethanol. Also, there is no requirement for the octane of the gasoline used to make it, so E85 is typically somewhere between 95 MON and a widely-claimed-but-seldom-achieved 105 MON. The best quality E85s, which are quite rare, when rated by the (R+M)/2 method consumers understand, are 95-97-oct.
That said, you could not run E85 in any Corvette engines without major modification to the car's fuel system and some changes to the engine.
Old Apr 2, 2009 | 01:33 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Alcohol will eat or corrode aluminum and rubber so you'd have to change out damn near your entire fuel system. I believe Flex Fuel cars use a specially lined fuel tank and stainless steel fuel lines and assoc hardware.
Old Apr 2, 2009 | 03:29 PM
TEXHAWK0's Avatar
TEXHAWK0
Why would anyone use E85 unless there was no other choice?
It is corrosive, costs more than gasoline, is harder to find, and gets worse fuel mileage.
Old Apr 2, 2009 | 03:32 PM
Numb's Avatar
Numb
It's great for boost.
Old Apr 2, 2009 | 05:12 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
Yep! A lot of evo and sti guys run the e85
Old Apr 2, 2009 | 05:26 PM
stainless40cal's Avatar
stainless40cal
100 percent false statement
Old Apr 2, 2009 | 09:49 PM
Mr. Furley's Avatar
Mr. Furley
Yeah, I'm in the Evo world also. All I needed was a tune and larger injectors. It's also $2.30 - $2.79.
Old Apr 2, 2009 | 09:55 PM
LT1driver's Avatar
LT1driver
stainless you don't know what you are talking about in your bold statement. Death to E85
Old Apr 3, 2009 | 12:03 AM
Millenium Z06
Moderator
How do you claim that someone is 100% false then offer no explanation as to your reasoning?
Old Apr 3, 2009 | 10:27 AM
vettelover84's Avatar
vettelover84
The happy face is beating it with a hammer, what else do you need!!??
Old Apr 3, 2009 | 10:44 AM
redtopz's Avatar
redtopz
Actually there are many people running E85 in boosted cars with no problems. I'm converting my supercharged LS2 GTO to E85 right now. No engine modifications necessary, just larger injectors and fuel pumps. However unless you are going for major power in a boosted engine I would just run gasoline.
To E85 Z's?
