CLB - K Harness Question
Look in the Tech section for a stickied post, all sorts of info in there
CLB is available from Corvettes of Houston, Corvettes of Dallas and Thunder Racing, all 3 are forum supporting vendors. Cost is about $50 plus shipping. Takes about 30 minutes if you have any mechanical abilities or perhaps an hour if you don't.
Here are the instructions you should use:
http://www.ls1howto.com/index.php?article=24
Follow them EXACTLY.
Here's a picture of the K Harness:
http://forums.corvetteforum.com/show...ight=k+harness
When the dealer installs the K Harness he installs it in series between the actuator and BCM. ie Actuator-K Harness-BCM. You first get the wheel unlocked. Then when you install the CLB you are disconnecting the K harness (and hence the actuator as well) and connecting the CLB to the BCM. The BCM now sends its signals to the CLB. The CLB being essentially an electronic relay turns the BCM signals back on the BCM as completed signals keeping the BCM happy. CLB being electronic is far more reliable than the electro-mechanical K Harness relay.
The column can remain locked when you insert the key into the ignition for any of several causes. For example the K Harness if it is installed has failed, or the lock ring and lock pin may have worn sufficiently for the pin to jam in the lock ring, or the battery may be weak enough to not be able to operate the actuator and/or K harness if it is installed. If any of those are the reason(s) for the column lock then you can get the column unlocked easily enough to then be able to install a CLB and be done.
If the actuator itself has totally failed then it is more difficult to get the column unlocked but if you are mechanically capable even that can be gotten around. By the way the chances of the Actuator totally failing is pretty small.
What you MAY have read is that the CLB cannot unlock the column. You first need to get the column unlocked and then install the CLB. When you install a CLB you first disconnect the Actuator, the electric motor that actuall inserts/withdraws the lock pin into/out of the lock ring, so the lock pin no longer has a way to operate.
If the car is at the dealer, do NOT let them sell you a new actuator if you plan on installing a CLB. When the CLB gets installed the actuator gets disconnected and is no longer used. IE column will ALWAYS be unlocked. Dealer will charge you somewhere between $350 and $800 to replace the actuator and in 99% of the cases it is only the microswitch in the actuator that has failed. That issue can be gotten around with the install of a CLB.
Let me know if you have any questions about this.
If you install the CLB inplace of the actuator and K Harness then the column will never lock up again even if the CLB were to fail. ( Very low likelihood the CLB will fail compared to the actuator or K harness failing but then ANYTHING man made can fail). If the CLB were to fail you could still experience the fuel shutoff because there is nothing to send completed messages to the BCM. You could find a tuner with either the HP Tuners tuning software or the EFI Live tunering software and have the PCM reprogrammed to set the fuel shutoff value to a very high number like 255mph. However the ONLY two tuner tools that can reset the fuel shutoff speed are the two mentioned above. Cost for a tuner to reprogram the shutoff speed is typically less than $50. Some folk report paying only $20.
Thanks for providing the info on how the c/l system works.I have decided to install the clb.Does Gene Culley sell the bypass? Looks like the toughest part is removing the knee bolster & insuring the wiring is correct.
Thanks again
Have a Happy Easter.
robsc501
Here's the link agaim to what the K Harness looks like:
You can just disconnect the K Harness connector and leave it where it is unless you want a trophy for your work bench.
Thanks again
robsc501
