Questions
Old Apr 5, 2009 | 03:32 PM
Lancejoker's Avatar
Lancejoker
Default Questions
Just a couple. Does any one here drive summer tires year round? What is the reason they can't be driven in freezing temps? And finally,do we get a discount at Tirerack.com through the forum?
Old Apr 5, 2009 | 03:36 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Summer tires in sub freezing temperatures are not a good idea - the tread compound doesn't warm up enough to give sufficient adhesion, and the end result could mean a disaster. Also - summer tires are not meant to be driven on wet cold roads for the same reason.
Rubber reacts to temperature, and gets more sticky as the temperature rises. Summer tires are great on dry hot roads, but terrible on cold wet roads.
I am not aware of any discount offered by Tire Rack to CF members.....
Old Apr 5, 2009 | 03:51 PM
Lancejoker's Avatar
Lancejoker
Thanks. Exactly what I was looking for.
Old Apr 5, 2009 | 06:32 PM
ALLEGRO's Avatar
ALLEGRO
I just purchased Firestone Wide Ovals back in December. I love the tires, look great, really grip....but only when it is warm(er). Below about 40F it is really difficult when you first leave the house.
All in all, they can be driven, but it should NOT be your DD.
Old Apr 5, 2009 | 07:18 PM
TEXHAWK0's Avatar
TEXHAWK0
My Z06 is a daily driver and I only have one set of Goodyear F1 SC tires that I drive on year around. There was one time that my car suddenly went sideways in freezing temperatures, but I just wrote it off to an active handling malfunction...I turned it off after that and never had another problem.
Old Apr 5, 2009 | 07:36 PM
e6bailey's Avatar
e6bailey
I try and drive my Vette right up until the snow starts flying for good. My OEM Run Flats actually did ok in cold temperatures and even snow. This last fall I switched to Ultra High performance summer tires and they had near Zero traction in Cold/Wet roads.
Old Apr 5, 2009 | 08:04 PM
I drove my car with the OEM Goodyear runflats on it in the winter, but traction was severely limited. It would get me around, but there were some anxious moments.
Old Apr 5, 2009 | 11:24 PM
tlc0706's Avatar
tlc0706
Found out the summer tires are kinda spooky in cold weather...
Old Apr 6, 2009 | 02:59 AM
Lancejoker's Avatar
Lancejoker
I've driven in snow in the OEM runcraps. Didn't really bother me that much. Kinda what I expected out of a Corvette in the snow,you know?
Old Apr 6, 2009 | 11:21 AM
Lancejoker's Avatar
Lancejoker
Anybody here running the Bridgestone Potenza RE960AS Pole Position?
To Questions
