changing anti-freeze
Old Apr 5, 2009 | 06:24 PM
wrinkles's Avatar
wrinkles
Cruising
Default changing anti-freeze
Can someone help old wrinkles out, if you flush the radiator and drain it if I put a 50/50 mix back in isn't there still a lot of plain water left in the block which would delute the mix? Thanks for the help.
wrinkles
Old Apr 5, 2009 | 06:42 PM
TEXHAWK0's Avatar
TEXHAWK0
The system holds 12 quarts, and you can drain about 8 quarts without draining the block.
If the block has 100% water, just add 6 quarts of pure Dexcool first, then add the last 2 quarts of water.
OR, you could add 4 quarts of pure Dexcool, then finish with 50/50 mix.
(you didn't already buy the pre-diluted Dexcool did you?)
If you have not already done the flush with water, and you did not push the antifreeze to the 5 year limit, I would just drain the 8 quarts and if it looks clean, just add 8 quarts of the 50/50 mix.
I never let my Dexcool go over about 2-3 years, so I just replace what I can drain without flushing the whole system. The antifreeze also lubricates the water pump, so I don't really like to run pure water even for short periods of time or drain all the liquid out of the pump while it is hot.
Old Apr 5, 2009 | 07:02 PM
ALLEGRO's Avatar
ALLEGRO
I flushed mine 5 times to get clear water out. Then you have the issue of putting DexCool back.......just flush and let her go.
Old Apr 5, 2009 | 10:39 PM
8VETTE7's Avatar
8VETTE7
with Texhawk0. He is right on the money. If you flush the system using water, you will end up with 4 or a little more quarts of water in the block. Need to add 100% Dex Cool for about 4 quarts ( resulting a near 50 50 mix in the cooling system) and then top off with a 50 50 mix..........
Old Apr 5, 2009 | 11:27 PM
1FUNVTT's Avatar
1FUNVTT
Sorry to highjack, but it is related...
If you drain the engine block by way of the drain plugs (and I am assuming there are the two standard 9/16 plugs above the oil pan & center of the block like the older model small block/Chevy), do you find leakage problems after reinstalling the plugs?
Old Apr 6, 2009 | 08:58 AM
bucwheat's Avatar
bucwheat
Yea ,what he said,that's not hard to figure out.
Old Apr 6, 2009 | 01:46 PM
robsc501's Avatar
robsc501
Hi There:
On the c5 cooling system there are 2 engine block drains. The one on the left side is located at the engine mount bracket & the one on the right side is located behind the starter.You cannot access these drains plugs with the engine installed in the car.This means you can only flush the cooling system.
robsc501
To changing anti-freeze
