my car's been making this single or 2 click noise right at takeoff, it doesn't do it everytime but it does do it pretty often, again this is only right when i'm slipping the clutch in 1st and the car is just barely rolling, it's coming from the rear of the car, sounds like right rear, any ideas?
My car does the exact same thing, I would also like to know what this is!
<breaths a sigh of relief, i thought it was leading up to something more serious like the axle itself, i'm doing my trans/diff fluid this weekend at my buddys with a lift so i guess we'll just have to pull the rear wheels off and address this problem, thanks for the help!!
Before you remove the rear axle nut, you might want to check the torque on it so that you will know if you have a problem with the nut getting loose, or just rust buildup on the splines and hub.
It is not the splines themselves making the noise, it is the stick/release action of the surface where the hub pulls into the bearing hub. IT will usually occur when you change the load on the drive axles. Mine would pop in both directions.
