Wheels on a c5 corvette
Old Apr 6, 2009 | 02:56 PM
sonz06's Avatar
sonz06
From: car is located in st. louis most of the time MO/AL/TX/LA
Default Wheels on a c5 corvette
some of you may know this, I was curious if an 18 by 10.5 will work for the front of a c5 corvette and maybe recommend a tire size to go along with it I was think a 275? any thoughts please let me know ?
thank you
Old Apr 6, 2009 | 02:59 PM
Dominic Toretto's Avatar
Dominic Toretto
Make sure the offset is correct. Also I think a 10.5 is too big for the front, but I could be wrong.
-Alex
Old Apr 6, 2009 | 03:02 PM
sonz06's Avatar
sonz06
I wanted a 9.5 for the front but they are on back order for another 2 months
Old Apr 6, 2009 | 03:11 PM
Dominic Toretto
Wow, what wheels are you considering with such a long back order?
-Alex
Old Apr 6, 2009 | 03:54 PM
IMXCITD's Avatar
IMXCITD
I feel like it may fit...but would probably rub...so I would stick w/the 9.5 up front.
Old Apr 6, 2009 | 05:56 PM
Blue Smooth's Avatar
Blue Smooth
I run 18x10s w/285/30/18s...good to go.
Old Apr 7, 2009 | 09:19 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
thank you
^^There are people who track their cars that run 18 X 10.5 all the way around. So it can be done. However, I think they make stick out a little in the front and also you may have a problem with rubbing at full steering lock. If your tires stick out they will sandblast the fenders, which after a while won't look so hot.
I know a 275 on a 10" rim will fit under the front fender with no problems. Not sure about 10.5" rim.
The other thing you need to be aware of is to make sure the front tires have a smaller diameter than the rear. Many people recommend at least 1/2" difference. If you don't do this you can have problems with traction control. Traction control kicks on when the rears start spinning too much in relation to the fronts.
Old Apr 7, 2009 | 10:10 AM
pjlee1's Avatar
pjlee1
thank you
you would be correct!! also, a 19" x 11" will take a 305 rear
Old Apr 7, 2009 | 12:17 PM
Tonycpa's Avatar
Tonycpa
I have a 275 tire on my C5 mounted in an 18 X 9.5 wheel.
Additionally, I run 18s all around and have no problems (see tire wheel sizes in my signature).
Best of luck to you.
thank you
To Wheels on a c5 corvette
