Tools required?
Old Apr 8, 2009 | 05:43 PM
versatile's Avatar
versatile
Default Tools required?
For those of you who have lowered your Vette on stock bolts, "What tools are required to do it?"
Old Apr 8, 2009 | 06:24 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Here's a thread I found before I did mine. Good luck!
Old Apr 8, 2009 | 06:37 PM
csexton's Avatar
csexton
Jeff, the above site is a good guide. I lowered mine (01) a month ago. I can share a couple of tips that made my work easier. Soak the front adjusters in PB Blaster and let it sit for a day. The top of the front lowering bolts can be stripped easily with normal pressure from the wrench (socket). I used a vise grip to work the bolt back and forth. It still did not want to turn. The bottom of the adjuster has a rubber bushing that rests on the a-arm. This bushing can become vulcanized to the a-arm as mine did. I used a narrow putty knife and slide it between the bushing and the a-arm. The adjuster was easy to turn once the bushing was free. I can now turn them by hand. I hope this helps.
Chuck
Old Apr 8, 2009 | 07:18 PM
dobewillie's Avatar
dobewillie
good post
To Tools required?
