[Z06] ****Poly Bushing Replacement Service****
Old Apr 9, 2009 | 10:57 AM
Robert@SPEEDSOUTH's Avatar
0Robert@SPEEDSOUTH
Former Vendor
Default ****Poly Bushing Replacement Service****
Are you dreading the installation of the control arm bushings on your C5, C6, or C6Z? Does your car have EVERYTHING...but bushings?
Maybe you do, or don’t, know how to do it, but you’ve heard nothing but how frustrating the replacement process is.
Well, we have a solution.
We have teamed up with Pfadt Racing and arranged a special promotion to offer a control arm bushing replacement service to the Corvette community.
The service is simple, all you'll need to do is remove your control arms, it doesn't take very long, and send them to us. We'll install all of the bushings for you plus whatever options you choose. No more cussing, no more blood and tears, just these fixed prices for parts & installation.
$750 for C5/C6
$850 for C6Z
Options include:
Zerk fittings & installation: $200set
Pfadt Balljoints & installation: $125ea
Pfadt Racing describes the performance benefits & design aspects of their product best.
"The factory bushings are known to deflect more than a ¼ inch in turns which equates to almost 1 degree of lost camber. With our poly bushings that deflection is gone and you’ll make the most of your alignment.
Our poly bushings are graphite impregnated for long life and low friction. They are engineered with special grooves to maintain lubricant on the bearing surface, keeping the noise away. We include lots of lube specific to our polyurethane. In addition, we’ve engineered custom aluminum sleeves for light weight, low friction operation. The front upper pivots are machined with an offset to offer maximum camber adjustment.
Unlike most kits available, the Pfadt kit also includes the lower rear shock mounts, setting it apart from the competition."
*Please note that polyurethane bushings will begin to make noise over time, no matter the brand, and regardless of how much, and what type of grease was used during the installation process. We use a grease originally designed to lubricate mechanical components in a saltwater environment. We believe that it is the longest lasting grease for this type of application. A poly. bushing will make noise sooner than a rubber bushing will. A bushing is considered a wear item. Suspension bushings, whether factory rubber, or a performance poly., were not designed to last forever.
Old Apr 11, 2009 | 11:41 PM
0Robert@SPEEDSOUTH
Former Vendor
Old Apr 13, 2009 | 07:36 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What are the zert fittings for ? The poly bushings ?
Old Apr 13, 2009 | 01:59 PM
0Robert@SPEEDSOUTH
Former Vendor
Yes, it allows grease to be introduced around the sleeve.
Thanks for asking. I've had several pms about that same thing.
Old Apr 13, 2009 | 03:46 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's sounds like a great deal. Has Pfadt come out with the upper ball joints yet ?
Old Apr 13, 2009 | 06:21 PM
0Robert@SPEEDSOUTH
Former Vendor
If they are, I haven't heard yet. The lower one is the one that is subjected to so much heat, the upper is further away from the brake.
Old Apr 17, 2009 | 10:37 PM
0Robert@SPEEDSOUTH
Former Vendor
Friday night bump
Old Apr 18, 2009 | 08:31 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Hi Robert,
Any pictures of the installed Zert fittings in the "A" arms ?
Old Apr 18, 2009 | 07:37 PM
0Robert@SPEEDSOUTH
Former Vendor
Hi Robert,
Click this link.
http://forums.corvetteforum.com/auto...service-2.html
Let me know if you have any questions.
Old Apr 18, 2009 | 07:44 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Click this link.
Thanks, You're on my shopping list when my car get's finished up at the body shop.
Thanks,
Tony
Old Apr 30, 2009 | 12:39 AM
0Robert@SPEEDSOUTH
Former Vendor
I just recieved an e-mail from Jordan at Pfadt, they have just increased the price of their bushing kits by $100/set meaning our pricing had to move up $100 too.
Our updated pricing for the kits AND installation is now:
$750 for C5, C5Z, and C6
$850 for C6Z
All other prices remain the same.
Old Sep 5, 2009 | 11:36 PM
0Robert@SPEEDSOUTH
Former Vendor
September Special !!
Call us gluttons for punishment, but from now until the end of the month we will be offering our Poly Bushing Replacement Service again.
Pricing for the kits AND installation are now:
$850 for C6Z
Options include:
Pfadt Balljoints & installation: $125 ea
To ****Poly Bushing Replacement Service****
