Stock catback-AM I MAKING A MISTAKE?
Old Apr 9, 2009 | 11:51 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Default Stock catback-AM I MAKING A MISTAKE?
Hello friends----I have always thought that I was making the
right decision by keeping my stock catback. I thought that
folks changed them for the sound and only sound.
Now I have read a couple of posts where changing to
a aftermarket catback is picking up power.
Here's my stiuation I have a Vortech supercharger, ARH,
X-pipe, cats, a bunch of bolt-on's on a 346 cu in.
making 520 rwhp/500 tq.
Are other member's making this kind of hp with stock
catback ? Or, are you running aftermarket catback's for
power not sound. Believe me I have enough noise as my
vette sit's now. Do you think I have that much back
preasure that I am choking the motor?
Thanks for taking the time to read this and I will be
interested in your reply.---road pilot
Old Apr 9, 2009 | 11:59 AM
Dominic Toretto's Avatar
Dominic Toretto
Most, if not all of the aftermarket catbacks are going to be the same 2.5inch diameter as the stock one. However depending on the routing of the pipes, whether they have mufflers or not etc, you MAY notice some minimal gains. I picked up my B&B bullets for the sound, as the rest of the exhaust is stock... for now.
-Alex
Old Apr 9, 2009 | 12:07 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Corsa here for sound and tips are much better looking then those factory caddy tips !
Old Apr 9, 2009 | 12:15 PM
bartsky's Avatar
bartsky
I think this is the first time I have ever seen someone with those kinds of mods and stock exhaust. If I could only do 2 things to a Vette, it would be intake and exhaust. I think you are cheating your car. Just my opinion though.
Old Apr 9, 2009 | 12:24 PM
Quickshift_C5's Avatar
Quickshift_C5
I swapped my exhaust for the sound only. I am absolutely sure there are power gains in swapping it, but whatever gains are there would be so little it's not really worth mentioning.
Yeah, I'm only aware of one aftermarket catback setup that is a full 3" all the way. The LG "Big 3" I believe is completely 3.
Old Apr 9, 2009 | 12:28 PM
DickieC.99's Avatar
DickieC.99
On an otherwise stock car one would see little to no gain with a new catback. Given your mods you'd see more, but how much, I don't know. Probably not enough to justify the $$ if the performance gains are all you're looking for. But combined with the much better sound and more aggressive look of the pipes coming out the back I think its worth it.
You might want to ask this question over in the FI section. I know those guys have tried a lot of different setups, from stock to straight pipes, to see the gains.
Old Apr 9, 2009 | 01:34 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
At a minimum id swap to Z06 Tis, they are alot lighter to begin with and flow excellent even for FI. Sound is better at WOT.
Old Apr 9, 2009 | 01:39 PM
Drewstein's Avatar
Drewstein
I bet you pick up 15-20rwhp by going to a free flowing muffler design. If you're only interested in the power it's up to you if it's worth the investment. I personally think the stock sound and look is terrible so it makes the decision much easier.
Old Apr 9, 2009 | 03:45 PM
Quick 68's Avatar
Quick 68
Default exhaust
Correct me if I am wrong but the stock Cat back is not a true 2.5 inch exhaust. I know the pipe is 2.5 for the Z06 but it tapers down right where it goes into the muffler to like 2.25 or so. Im happy with my LG big 3. I had some issues with the clamps not holding initially but I ended up getting a couple tack welds for extra insurance. The sound is nice. Not too loud and not too quiet.
Old Apr 9, 2009 | 03:50 PM
RBRBRNR's Avatar
RBRBRNR
I agree with many above about the pipe diameter, BUT the different muffler design allows for more airflow. Especially important when running FI.
Why do I like CORSA??? Because most of their product info. doesn't claim such and such HP gains, but WILL tell you how much more airflow you'll recieve after the install. My Corsa PaceCar flows 47% better than stock...and sound, wow don't even get me started.
Old Apr 9, 2009 | 03:51 PM
vettelover84's Avatar
vettelover84
Get the Stock Z06 TI cat back.... I love it.. Its not loud until WOT, it looks great, and its lighter....
Old Apr 9, 2009 | 07:57 PM
squidwards vert's Avatar
squidwards vert
IMO its about economics really.
Cat-backs alone are for looks and sound.
Price out a complete 1 7/8 LT header system w/ 3 inch collectors, cats, crossover, and cat back, which for your application I would go with the 3 inch set up from LG then figure 25-30 additional horses then make your decision.
Factor in looks and sound if that is what you are after too then decide.
You are making great power, up to you to decide if you want more and at what cost.
Consider buying a used cat-back and keep your old and try it out. If you don't like it, go back to stock.
Good Luck
Old Apr 9, 2009 | 10:43 PM
itzza427's Avatar
itzza427
Cat backs DO flow a bit better,,but as stated it's not much. When the advertise 10 to 15 horses you can bet they are stretching the truth as far as possible. IMO with your set up you SHOULD be able to better the advertised numbers by a little bit,,and look and sound a little better. If you want to keep the sound under control,,look into Corsa,,pace car or touring!!
To Stock catback-AM I MAKING A MISTAKE?
