Tunnel Plate ?
Old Apr 11, 2009 | 08:40 AM
moserbe's Avatar
moserbe
Black Max
Old Apr 11, 2009 | 09:47 AM
Corvette Don's Avatar
Corvette Don
Guys if you want to save some money I got 2 C6 tunnel plates and rivited them together to come out to be 1/4" thick (4 times thicker than a stock C5 plate), I went to the parts store and got ceramic header coating for $6 and did 4 coats and bolted it in to the car, NO more heat and DEF stiffer now . Cost was $100 less than buying a 1/4" coated plate from elseware. You can pick up C6 plates on the cheap used in the C6 for sale section. I was going to do 3 together but I figured 1/4" was more than enough.
Old Apr 11, 2009 | 09:54 AM
minitech's Avatar
minitech
For any of the plates you can put a couple layers of Dynamat Xtreme or similar to the inner side for more heat and sound control. While it is out it is the perfect time for that. Be sure the Dynamat is away from the edge where it bolts to the car to be sure of a good tight fit putting it back on.
Old Apr 11, 2009 | 11:50 AM
prplprl2's Avatar
prplprl2
Thank you for ALL of the replies!!
I am going to order a plate today!!
Old Apr 11, 2009 | 02:50 PM
Since you'll have the exhaust off, I'd sure do the tunnel plate at that time.
Old Apr 14, 2009 | 10:32 PM
prplprl2's Avatar
prplprl2
Default C6 plate works??
Okay....the best price out there by far is a C6 plate. Does this bolt straight on to a C5 without any modification?
What is the difference/improvement of the C6 plate vs. the stock C5 plate?? Does it make sense to use a C6 plate?
Thanks!
Old Apr 15, 2009 | 01:10 AM
Z06ster's Avatar
Z06ster
Originally Posted by Fastbird@FastbirdPerf.com
I plunked down for an Elite Engineering Thermal Abs tunnel plate. Best move I've ever made. Even with the turbo's down low I'm not catching extra heat in the cabin.
I also have an Elite Engineering tunnel plate with thermal abs. The difference was day and night as far as heat reduction in the cabin goes. I particularly appreciate this in the hot Southern Californian summers!
Old Apr 15, 2009 | 02:01 AM
JETZ's Avatar
JETZ
EE too!
