Stock Battery in 03?
Old Apr 10, 2009 | 02:53 PM
Fratbragen's Avatar
Fratbragen
Default Stock Battery in 03?
I'm sure this has been asked several times, so take it easy on me.
I don't think I have the stocker in, but want to make sure as I've heard of the leaking issues.
Thanks for the help as always.
Matt
Old Apr 10, 2009 | 04:22 PM
rboineau's Avatar
rboineau
Matt, I recently bought a 4500-mile '03 Coupe with its original battery. It was a grey AGM Delco, had been kept on a Battery Tender and was/is fine although I replaced it anyway. I don't think you have to worry about leaking batteries in '03s, but a couple minutes taking yours out to look underneath would put your mind at ease. The terminal clamps should not be overtightened, manual says 11 foot-pounds but getting a torque wrench in there is difficult at best. Just tighten securely, make sure the cable can't move, check again later. Quite a few C5 owners put an absorbent mat or plastic pan under the battery and I think that's cheap insurance. When you remove a C5's battery and look at the design which basically guarantees that any leaking battery acid will funnel right down to important wiring areas, you'll wonder what the hell the engineers were thinking. Good luck, Ralph Boineau in central South Carolina.
Old Apr 10, 2009 | 08:17 PM
Fratbragen's Avatar
Fratbragen
Very helpful!!!! Thanks much.
Old Apr 10, 2009 | 08:54 PM
chaase's Avatar
chaase
St. Jude Donor '12
My AC Delco stocker never leaked. It died after 6y.
Old Apr 10, 2009 | 09:04 PM
ALLEGRO's Avatar
ALLEGRO
Took delivery of my AE in January of 2003 and the OEM battery is still doing GREAT....probably jinxed it !!!!
To Stock Battery in 03?
