unable to find a trouble code. please help!
Old Apr 11, 2009 | 02:03 PM
Fasterer's Avatar
Fasterer
Default unable to find a trouble code. please help!
My 00 vert started running strange after gas fillup. After about 3000 rpm in 1,2 it almost sounded like a far off bike that had a card clipped to its spokes. I took it easy after that.I thought detonation or timing issue and lo and behold the service light came on. I used on board diagnostics to pull codes. Showed 10PCM P1040H. My service manual (3vol chevy) lists no such. Anyone have any idea if im wrong, the manuals wrong or the cars wrong.
Bill
Old Apr 11, 2009 | 02:19 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Not sure what the P1040 code is, But seeing it has an "H" after it means it is a history code and NOT a current code. I looked for the 1040 code and found nothing.
Check your gas cap.
Old Apr 11, 2009 | 02:27 PM
Fasterer's Avatar
Fasterer
Thats the first place i looked.Without going to Chevy is there a way for me to clear H codes. Then i can run it and see if it returns.
Bill
Old Apr 11, 2009 | 02:38 PM
Mr.Bill's Avatar
Mr.Bill
Bill
Is the car running fine now?
Here is a site that will tell you how to clear codes.
http://www.stengel.net/diccodes.htm
Old Apr 11, 2009 | 03:03 PM
Fasterer's Avatar
Fasterer
Right now its raining like hell in my part of CT. I'll take her out for a road test when the weather clears. I put a can of dry gas and octane booster in case it was s__t gas all along.
Bill
Old Apr 11, 2009 | 03:06 PM
Mr.Bill's Avatar
Mr.Bill
Bill
Did you get the code cleared?
Old Apr 11, 2009 | 04:37 PM
Fasterer's Avatar
Fasterer
I had erased the code by holding the reset but didn't know if this cleared all history codes. Shouldn't the service light thrown a current code.
Bill
Old Apr 11, 2009 | 04:52 PM
Mr.Bill's Avatar
Mr.Bill
you will see the display read manual mode and show each section, That is where I delete the codes, You can always run the test again and see if anything comes up.
You will only see a "C" code if it is still active, One thing about the C5 is they can for no reason show a code, Maybe grounding issues,,,Who knows.
Old Apr 11, 2009 | 05:13 PM
slothy's Avatar
slothy
p1040 or p0140 ?
p0140 is Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
Old Apr 11, 2009 | 05:26 PM
legman's Avatar
legman
Bill
I could be wrong but, I've heard a long time ago....dry gas and fuel injectors don't mix well together...
Old Apr 11, 2009 | 06:10 PM
Fasterer's Avatar
Fasterer
I can't be positive about the dry gas however i have run it in my 85 for years.I ran it in my camaro for over 300,000 miles (85 z28). thats all i know. As far as code i didn't transpose the #s. That was my first thought when the shop manual codes started the P's with no 1040.only 1111 #s.
Bill
Old Apr 11, 2009 | 07:26 PM
dobewillie's Avatar
dobewillie
good luck fast
To unable to find a trouble code. please help!
