how do you wire up a shift light?
Old Apr 13, 2009 | 04:27 AM
nickwfd92's Avatar
nickwfd92
Default how do you wire up a shift light?
I am thinking about installing a shift light in my 00 coupe M6.
I know you wire the red to + and black to - and green goes to the tach signal, but where do you get the correct tach signal on our cars.
Next question Who has shift lights and do you like them? Where do you have them installed, and what shift points are you using.
Thanks for the input.
Old Apr 13, 2009 | 07:46 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Kind of overkill for street use. Just IMO.
Old Apr 13, 2009 | 10:11 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Mine is mounted on the a pillar, connected at the rear of the gauge
cluster. It's a Raptor light, chrome w/blue led, set at 6,700rpm
Old Apr 13, 2009 | 10:21 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
There's a large cluster of wires that run up to the gauges. Unbundle the cluster and you'll find 4 white wires. One of them is the tach signal.
I took a sewing pin and stuck it into each wire, one at a time... fired up the car and checked if the light would come on (setting the light at 2k for testing). I hit the correct white wire on my second attempt.
Other than that, you have to run a wire over to the ECM. It's pin 10 (also white wire) on the blue connector.
Old Aug 30, 2009 | 06:12 PM
JeremiahsC5's Avatar
JeremiahsC5
My car only has 3 white wires. Not having any luck getting the need to jump on the tach either.
Old Aug 30, 2009 | 06:19 PM
Patches's Avatar
Patches
Here's the best how-to on it.
http://forums.corvetteforum.com/c5-t...-big-pics.html
I hooked mine up under the passenger footwell area and mounted it on the A-pillar..
Old Aug 30, 2009 | 07:10 PM
JeremiahsC5
Ok, so I finally got it installed and working properly. My advice to the next guy. There can be four or three white wires to choose from. Test all the wires. When testing the white wires push hard and make sure the light tester is making contact with the wire. I only had the tach jump one time for me.
To how do you wire up a shift light?
