Driver seat slides back and forth
Old Apr 13, 2009 | 07:46 PM
vette.mix's Avatar
vette.mix
Default Driver seat slides back and forth
Driver seat slides back and forth about an inch when im driving, appears not to lock in place. Does the track need to be replaced.
Thanks for your help in advance
Old Apr 13, 2009 | 08:04 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Sounds like the dreaded "Rocking Seat" issue. This post will help plus check out the detailed "fixed" in the Tech Forum:
http://forums.corvetteforum.com/c5-g...h-as-well.html
Old Apr 13, 2009 | 08:12 PM
dobewillie's Avatar
dobewillie
Old Apr 13, 2009 | 08:13 PM
MagRedConv's Avatar
MagRedConv
Check your post in the Tech section, someone chimed in there as well.
Old Apr 13, 2009 | 08:16 PM
tlc0706's Avatar
tlc0706
Try this:
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
Old Apr 13, 2009 | 08:36 PM
vette.mix's Avatar
vette.mix
Thanks a lot for all the help, looks like I have a small job to do this weekend
Old Apr 13, 2009 | 08:43 PM
10U 99's Avatar
10U 99
these are the little buggars causing the problem.
Old Apr 13, 2009 | 09:03 PM
jrose7004's Avatar
jrose7004
Well congrats, you just found the problem that thousands of C5 owners before you have discovered! The rocking seat!
Old Apr 13, 2009 | 10:20 PM
I've got a few word files that addresses the rocking seat problem. If you'd like a copy, just PM me your e-mail address and I'd be glad to send them to you.
To Driver seat slides back and forth
