Climate Control Display
Old Apr 14, 2009 | 10:54 AM
VRY YLW's Avatar
VRY YLW
Navigator
Default Climate Control Display
The display of the climate control on my 2002 coupe is barely visible at daytime. The brightness is very low. When I turn on the lights and the dash brightness is adjustable it goes up and down with the control. But it is always only half as bright as the radio for instance.
Any hints?
Old Apr 14, 2009 | 11:07 AM
poolboy's Avatar
poolboy
It is a known problem - if you are handy with a soldering iron it can be a DIY fix....
Old Apr 14, 2009 | 11:12 AM
VRY YLW's Avatar
VRY YLW
Navigator
I think I can handle that, if I would know what and where to look for. Is there a write-up already posted on the board? I tried several searches bit didn't find anything.
Old Apr 14, 2009 | 11:21 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
With all the great mods now available (double din center consoles, NAV systems, custom steering wheels, etc.), it would be nice to have a legitimate aftermarket option for the dated climate control unit/display.
Something along the line of the C6 perhaps. Never saw one and posted a separate thread earlier with a limited response. Without a full understanding of the electronics involved and with the ability to modify the center stack for double din NAV systems, etc., perhaps any late model GM climate control could work.
Old Apr 14, 2009 | 11:30 AM
japc5's Avatar
japc5
Yes see post #26 in this DIY thread found in the sticky at the top of the C5 tech forum.
http://forums.corvetteforum.com/c5-t...with-pics.html
Old Apr 14, 2009 | 04:31 PM
VRY YLW's Avatar
VRY YLW
Navigator
Thanks a lot, that should do it. Appreciate your help.
Best regards,
Reinout
Old Apr 14, 2009 | 06:19 PM
brzman's Avatar
brzman
Heres an article I copied a while ago. The original has pics. Theres a vendor that fixes these things quite cheaply if you dont fancy the DIY
Climate Control Fading Fix
Written by Brad Moore with original instructions from fugedaboudit.
Pictures by Zach Walker.
1. Pry up the panel that goes around the shifter and pull it off, set aside (you don't have to disconnect the TCS wire - just lay that panel on the seat. The wire will extend far enough). After removing that, you'll see two bolts in the middle that go into the floor. Remove those.
2. Open the center console and take out the rubber bottom. It just sits on the bottom - no need to remove any screws. Under that rubber bottom will be two bolts which look the same as the ones in Step 1. Remove them.
3. Now look at where the center console piece and the dash meet. On the backside of this (down by the gas pedal) you will see a bolt on both the driver and passenger sides. Remove those two bolts. The entire center console should now be free to move.
4. Remove the ash tray to help gain a little bit of clearance. Pull the console unit back (start by pulling from the area where the dash and console meet), possibly pulling up and pushing down on the black part of the shifter unit (where it says PRNDL...etc). Just work it a little - enough to get the entire console moved back a few inches to get clearance for the climate control unit. (See Picture Below)
5. There are two phillips head screws holding the climate control unit in place. Unscrew those and remove the unit (disconnect the wiring also).
6. There are a few tiny bolts holding the plastic cover on the climate control unit. Take those out and pull the cover apart to reveal the circuit boards.
7. There are two circuit boards - one is the power supply and one is the display board. The display board is the one with the digital display built in - you do NOT need to mess with this board. I recommend not disturbing it much, as I dropped the plastic things that are behind the buttons and spent a long time trying to find them! Just unplug the connector that runs between the two boards and focus on the power supply board. The PS board is also held on by four bolts similar to the ones holding the climate control casing together.
8. Flip the power supply board over so that you are looking at the side that would be facing the rear of the climate control unit (I think. My memory is a little fuzzy on this one, but you'll find what you're looking for eventually). Look around the board for some small resistors (we think they are resistors anyways - they are flat and black) that have the number 241 on them. There are about 7 or 8 of them overall and bunched together. A few of them are a couple of inches away, but they are all in the general vicinity. These are the problem pieces. (See Picture Below)
9. Using a small soldering iron, touch the iron on one side of the resistor to melt the existing solder. Then add a little bit of fresh solder. Only add a little bit - that's all it takes! I generally added too much, so I had to mess around with picking that stuff up. A more experienced solderer would probably not have a problem with it. Also, if any of the resistors slides away when you do this, push it out of the way (keep it facing the same way that it was), apply a little bit of fresh solder on the contact points of the board, and then put the resistor back into its spot. Then, holding the resistor with a blunt object (toothpick, etc), melt each end into the fresh solder. Try not to keep the iron on the board too long - you could damage something.
10. Once done soldering, put the board back in the climate control casing and connect the two boards together. Go out to the car and connect the wiring harness to the unit, turn the car on, and see if it works. It should work now! I had problems at first because I didn't have the wiring harness from the car hooked up tight enough, so I was getting some strange results - so be sure that you have it plugged in tightly.
11. Once you are convinced it's working properly, put everything back together and you're all set!
__________________
2002 A4 Convertible, Mag Red II
Euro head and tail lights, Z06 screens, frame savers and rocker rails, Pioneer AVIC X1R nav/DVD player, EE catch can.
compliments of Dee Gee
Old Jan 19, 2010 | 05:48 PM
pscott's Avatar
pscott
<<Heres an article I copied a while ago. The original has pics. Theres a vendor that fixes these things quite cheaply if you dont fancy the DIY>>
Could you tell me the name of the vendor that has a quick fix for this?
Thanks.
Old Jan 19, 2010 | 08:23 PM
rws.1's Avatar
rws.1
digitalguy_1@charter.net
Old Jan 20, 2010 | 05:29 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
JW Motoring also does it...
Old Jan 20, 2010 | 11:03 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Ship your unit to us and we'll fix it.
To Climate Control Display
