Single Zone HVAC LED Swap
Old Apr 15, 2009 | 12:08 AM
jasonprobasco's Avatar
jasonprobasco
Default Single Zone HVAC LED Swap
Does anyone have information on how this is done? It doesn't seem to be covered like the dual zone HVAC units. I have the unit disassembled, I have 3mm flat top LEDs with resistors to match. The primary piece of info I need is which side of the current bulbs is the positive side or how do I test that to find it? There is a small write-up on a NEW LED MOD thread, page 2 but any addition info anyone can offer would be helpful. Thanks, Jason
Old Apr 15, 2009 | 12:39 AM
nickwfd92's Avatar
nickwfd92
I am wondering the same thing, good luck hope it works out and can you post pics.
Old Apr 15, 2009 | 12:43 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Old Apr 15, 2009 | 12:55 AM
CUlookin's Avatar
CUlookin
Here's how I did it when I did my dual zone HVAC LED swap... First do one LED in the unit, and with it still apart, plug it back into the car and turn on the running lights and see if it lights up... If it does, your golden, if not, flip it around and try again. Once you have the first one correct, you'll need a 9V battery and a way to get leads off of it to touch the HVAC LED poles... I found an old stud finder around the house that used a 9V, the kind that hooked up to the battery with the leathery looking flat black piece, and stripped the 24 gauge wires to expose <1mm leads.
You'll then want to remove the next bulb and touch these battery powered leads up to the exposed solder points and see if your correctly installed LED lights up. If not, you have to reverse the positive and negative. Do this for each one and you should be golden...
Here's a pic of me doing this with my Radio. As you can see, this is me reinstalling it in the car to check to see if I had the polarity correct...
You can kinda see the battery thingy in this pic...
I'll go find my little battery tool and post a pic in a minute. So hold tight! It's worth the results when you're done!
Best of luck with the project!!
Old Apr 15, 2009 | 01:10 AM
CUlookin's Avatar
CUlookin
Ask and you shall receive! Just a quick word of advice on this, DO NOT let the ends of the leads touch! You'll be using it over and over with each LED you do and the more you pick it up and put it down, the more of a chance it will happen. I was working on my HVAC and didn't even think about this until I went to pick it up after the leads had been touching I guess for about 2 minutes and the battery burnt the $hit out of my fingers!
Hope this helps, I know it made my install a lot easier and no guessing on polarity...
Old Apr 15, 2009 | 02:36 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I mapped em out when I did my first one. I'll try and make a diagram or just post up a verbal description if that would be accurate... These are a real PITA to get to look good and to make the temp dial change color;
Those pics were my first attempt, I've since refined it. The whole upper area is lit by only four bulbs which is fine for incandescents but NOT LEDs with thier narrow light beam. I ended up using a LED strip and circled the frame on the upper portion of the faceplate...
Old Apr 15, 2009 | 02:49 AM
tstar's Avatar
tstar
OK this should work for you, looking at the front of the board left to right;
Top Row
Bottome Row
+ - + - + - + - (all the same)
To bench test it apply voltage to pins E,J and M and ground to K
HTH
Tim
Old Apr 15, 2009 | 10:07 PM
jasonprobasco
Thanks for the info everyone
Old Apr 16, 2009 | 09:33 PM
jasonprobasco
bump
Old Apr 16, 2009 | 09:35 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
I like the dual colors for the Temp ****, was wondering if you could do that with the passenger side of a dual HVAC, if so which ones?
Old Apr 16, 2009 | 09:38 PM
CUlookin's Avatar
CUlookin
Mine is, used white LED's and the blue casts a blue glow on the passenger **** and the red turns it red!
Old Apr 16, 2009 | 09:46 PM
BigTattooMan
St. Jude Donor '10
The line on the **** changes red with the white? I probably messed up my first question, or you answered it and I'm having a slow moment, but that will make the line turn red when you turn it towards the heat, like the pictures Tstar poasted? I think I consufed myself, I'll get a Red Bull and re-read...
Old Apr 17, 2009 | 03:30 AM
tstar's Avatar
tstar
I always install a Blue LED under the Blue sweep and a Red LED under the Red one;
Even if doing white;
The only real issue is that the plastic surround around the **** acts as a wave guide and you'll get bleed over in the neutral position making it look purplish. Blue also seems to be a dominate wavelength and over powers Red, as you can see in the "Passenger" script... the pictures make it look worse then it really is though.
CUlookin - I'd love to see some pics of how your's changes color with the white LEDs behind the sweeps! Maybe I'm doing it wrong...
Tim
Old Apr 17, 2009 | 03:20 PM
BigTattooMan
St. Jude Donor '10
Thank you
Old Apr 17, 2009 | 03:30 PM
CUlookin's Avatar
CUlookin
Nevermind, looks like I was lunchin' and needed the redbull. The **** stays white all the time, but it's a hyper white so it looks good. Haven't driven the car in a long time and guess I was mistaken!
Old Apr 17, 2009 | 03:33 PM
BigTattooMan
St. Jude Donor '10
Hope you got your redbull! Yes, with two white LED's in the area, the white portion of the **** turns blue when it's on the cold side and red when it's on the red side... I'll go snap a few pics for ya.
All rud bulled up and ready to go! Thanks for the help, looking forward to the pics...
Old Apr 22, 2009 | 11:41 PM
jasonprobasco
bump
To Single Zone HVAC LED Swap
Old Apr 23, 2009 | 03:00 AM
tstar's Avatar
tstar
Do you still have questions about the polarity of the bulbs?
Tim
Old May 19, 2014 | 11:39 PM
GeneralMotors4Life's Avatar
GeneralMotors4Life
I know that I am digging this thread out of the grave but I just wanted to give some input on the polarity of the bulbs.
I followed a previous post in this thread and it was incorrect.
Looking from the front of the board from left to right
Top:
Bottom:
The whole board was exactly the same for the eight LED's on the single HVAC controller.
Good luck for all of those who come across this thread
Old May 19, 2014 | 11:57 PM
gtrslngrchris's Avatar
gtrslngrchris
Top:
Bottom:
That's not accurate for my single zone HVAC for my '98. I'd have to dig up my note I jotted down somewhere but it definitely wasn't identical across the entire PCB.
