pulls to the left under hard acceleration
Old Apr 15, 2009 | 08:29 AM
tomtana59911's Avatar
tomtana59911
Default pulls to the left under hard acceleration
Got the car out for the second time yesterday.Its pretty cool but is hard to control under hard acceleration.It wants to pull left!wondering if thats normal and is there a cure?
Old Apr 15, 2009 | 09:08 AM
Chevy-SS's Avatar
Chevy-SS
It should go straight............I would start with a 4-wheel alignment. Just my $.02
Could also be something in "Active Handling" or maybe something binding in rear suspension (on left side), such as emergency brake.
Bottom line, it should go straight. Anything else is dangerous.
Old Apr 15, 2009 | 11:34 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree
Old Apr 15, 2009 | 11:40 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
This may sound stupid, but is your tire air pressure good all the way around. Other than that possible alignment issues.
Old Apr 15, 2009 | 11:41 AM
Sinister-one's Avatar
Sinister-one
Funny you should bring this up. Mine does exactly the same thing ! Launch it and in rowing through the gears, the car pulls to the left and comes back to straight in between gear shifts... freaking odd.
And I've had the car aligned twice already !
Old Apr 15, 2009 | 12:02 PM
4DRUSH's Avatar
4DRUSH
Try putting your left hand at 12:00 on the wheel.
Old Apr 15, 2009 | 12:08 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Is the road even? Most roads have a crown (higher in the middle) for drainage/runoff.
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
If I remember right didn't you buy Flatout's car. Under hard acceleration with a supercharger your lucky you have traction under 70 mph. But I could be wrong.
Sinister-one
great advise.
Old Apr 15, 2009 | 12:10 PM
Sinister-one
flat road.
Old Apr 15, 2009 | 05:55 PM
tomtana59911
Your right on bud,I had about the same HP in my ffr cobra and it went straight as an arrow every time spinning or not.same roads to so im lookin for answers,It could be dangerous!
Old Apr 15, 2009 | 06:17 PM
WKMCD's Avatar
WKMCD
One thing often overlooked - change the fluid in your differential and make VERY sure you've got the correct amount of POSI additive in there. Too much makes the car pull one way and too little the other. I use RP which comes premixed with the additive so there is no need to add more.
Just my $.02
Old Apr 15, 2009 | 06:29 PM
damilleniumboy's Avatar
damilleniumboy
Just my $.02
cool, I did not know this.
Old Apr 15, 2009 | 11:39 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
Try turning the traction control off and see if the same thing happens. Mine has a habit of changing lanes NOW if I drive with it on, thats what happens when you get these cars in the HIGH HP ranges.
Old Apr 16, 2009 | 08:29 AM
tomtana59911
I am getting a servive traction control and abs light on dash,guy I bought it from said it was just a glitch in the system,was I mislead?
Old Apr 16, 2009 | 12:08 PM
yyzmsp's Avatar
yyzmsp
I get the Service Traction control notice as well and it is just the system is not used to a lot of HP. Just cancel and continue on. I dont get the ABS notice but it could all be related. I dont know what kind of HP you are running, but once you get above the 500 mark I have found that if you drive with the Traction Control on then pour the coals to it the system will sense a traction control problem and will try to adjust the car to keep it straight. With a whole bunch of HP the system over reacts and puts way to much correction in and the feeling of pulling to the left in you case, mine is instant lane changes. ( 427, 17 lb boost and 150 shot Nitrous). I run with mine off at all times and I have read that other folks go to Competitive mode. Me suggesting to turn it off and see how it handles was just a thought to try and see if it was related to your high torque. Cheers and keep us posted
Old Apr 17, 2009 | 11:27 AM
Independent1
St. Jude Donor '08
^^I can understand the traction control message showing up on the DIC if you step on the gas hard, but not the service message.
That would indicate a problem with the system. I have gotten the traction control message before when I have jumped on the car but it always goes away after several seconds.
Sounds like your TC/AH system may need servicing.
Have you tried turning off traction control to see how car handles on the same piece of road?
Don't know if you have ever seen this article before.
http://www.corvetteactioncenter.com/...ehandling.html
Old Apr 17, 2009 | 11:32 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
P-51 aircraft yes, Vettes NO.
To pulls to the left under hard acceleration
