[Z06] Psi
Old Apr 15, 2009 | 07:16 PM
guitar420911's Avatar
guitar420911
Default Psi
What is the optimal psi for my c5 z06 tires? FYI, regular driving.
Old Apr 15, 2009 | 07:25 PM
LT1driver's Avatar
LT1driver
go with what the stick says ... 30pse cold and you should be happy
Old Apr 15, 2009 | 07:34 PM
ducati888spo's Avatar
ducati888spo
It really depends on your driving style. More air will help in handling but the ride will deteriorate so you can experiment with different pressures. Start with the door sticker numbers and go up from there.
Old Apr 15, 2009 | 08:15 PM
James92's Avatar
James92
I run 32 p.s.i, good balance of handling and comfort.
Old Apr 15, 2009 | 08:44 PM
JGOAT's Avatar
JGOAT
Old Apr 15, 2009 | 10:36 PM
81c3's Avatar
81c3
It also depends on the tires rubber compound. Some tires are harder than others. For my F1's, I like 30 front and rear. It gives me the best tire wear and best all around ride.
To Psi
