[Z06] removing swirl marks with PC
Old Apr 18, 2009 | 02:34 PM
HUSKER-Z's Avatar
HUSKER-Z
Default removing swirl marks with PC
Using a Porter Cable...need advice using a swirl remover, either going to use Zaino Fusion, or 3M 5996 product. Main objective is to remove some swirl marks and clean up the paint, then will polish. Any advice guys?!
thanks so much,
dk
Old Apr 18, 2009 | 04:25 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I would try it by hand first, to play it safe...
For HAND use: apply a small amount of Zaino Z-PC Fusion to a cotton or foam applicator pad (draw an "X" from corner-to corner of your pad). Work a small area (no bigger than 2' x 2') with the Zaino Fusion, using firm motions. Work the product for as long as necessary - stop to occasionally check your progress. Circular motions may be used, but always finish with front-to-back or up-and-down motions. When satisfied with progress, continue to step 4.
For MACHINE use: Can be used by random orbital or (for experienced users) rotary. Select a moderate speed (RO - 4.5; Rotary - 1200rpm) and an appropriate cutting or polishing pad. Apply Zaino Z-PC Fusion to the buffer pad in a "star" pattern. Start machine slowly to reduce sling. Work a small (2' x 2') area with moderate pressure until satisfied with results.
Buff the area clean with a soft, lint-free, non-marring towel. If satisfied with the results, proceed to next section. If more buffing is required, repeat either step 2 or 3. Problem areas like door handles (where keys often scratch) may require a few applications for best results.
When done, apply either: Zaino ZFX enabled Z-2 PRO, Z-3, or Z-5 to the surface for a long lasting, great looking shine that will lock-in the results of your work with Zaino Z-PC Fusion.
Tip: If more "bite" is desired, you can mist a slight amount of clean water (from a spray bottle) while using Z-PC Fusion. The water will interfere with the buffers that encapsulate the abrasives and will produce a slightly stronger result. Water can also be used to minimize dusting when using a machine buffer (random orbital or rotary).
Old Apr 18, 2009 | 05:52 PM
stig-zzz's Avatar
stig-zzz
there is a ton of info on the correct processes in the use of your pc in the car care section ..... its all in the prep ,products and processes for a better then new swirl free finish
wash
clay
polish
protect
stop on over glad to help
trying to correct a C5 corvette super HARD CLEAR COAT by hand is very much a losing battle you will micro-marr your paint and not do much of correction
John Stig
Old Apr 18, 2009 | 07:47 PM
Quick Silver Z
Our local "sultan of shine" uses a heat lamp to soften the clearcoat!!!
To removing swirl marks with PC
