[Z06] Serpentine belt
Old Apr 18, 2009 | 10:11 PM
pcbunn's Avatar
pcbunn
Default Serpentine belt
How hard is it to change the serpentine belt on my '01 ZO6? Can I do it in my garage using standard tools?
Old Apr 18, 2009 | 11:00 PM
dracer173's Avatar
dracer173
yes all you need is 13 or 15 mm socket and 4" extention push the tensner in and slid the belt off look at the way the belt is on the pulies befor removing
Old Apr 18, 2009 | 11:09 PM
pcbunn's Avatar
pcbunn
Great, thanks for the info. I'm not actually sure it needs to be changed but I wanted to know if it can be done. Car is an '01 with only 25k but I'm planning to take a trip to Utah this June so I thought I would check it out. I'll get to the dealer next week to purchase new belt after I take a thorough look at it. Thanks again.
Old Apr 18, 2009 | 11:37 PM
briann510's Avatar
briann510
10 minute max job but make absolutely sure you have the belt in each pulleys grooves underneath the balancer....
Always care a spare belt in the trunk with 1 wrench needed to changer belt in a emergency.
Old Apr 19, 2009 | 10:30 AM
tramminc's Avatar
tramminc
Buy 2, keep 1 in the trunk, my son lost his 2 weeks ago. When I took a 600 mile trip I had a spare in the trunk with my full tool bag and pump kit.
Old Apr 19, 2009 | 12:40 PM
pcbunn's Avatar
pcbunn
Thanks for the excellent advice. When I get to the dealer I will purchase two ane stow it away in the trunk recession where I keep my spare oil.
Old May 12, 2009 | 07:33 PM
glkfam's Avatar
glkfam
Default Thanks for info
Need to do this right now. Thanks for the info on changing the belts, sounds easy.
To Serpentine belt
