c6z06 shifter conversion questions
Old Apr 19, 2009 | 10:50 PM
1raptor's Avatar
1raptor
Default c6z06 shifter conversion questions
So when doing the c6 shifter conversion what are all the parts you need?? I am considering the gmpartshouse route but if I can find the parts used what all do I need?? and what year donor car am I looking for?? I know the 08 was different. thanks in advance
Old Apr 19, 2009 | 11:02 PM
VettRick's Avatar
VettRick
Just contact Gene. He will set you up with everything you need...shifter unit, ****, and retainer screw. The "kit" is probably listed in his "monthly specials" post.
You can reuse your shifter boot by making the top a little wider. There are how-to's on the process. It is pretty easy.
You are going to like it!
Old Apr 19, 2009 | 11:20 PM
HWY HNTR's Avatar
HWY HNTR
1a. Its easy to do.
1b. Get some pliers for that metal wedge youll need to yank out from under the shift pattern emblem on the original ****.
2. Youll need to modify the shiftboot for the new ****. The neck is fatter, so youll need to tear a few stitches to compensate.
3. Enjoy.
Old Apr 19, 2009 | 11:43 PM
1raptor's Avatar
1raptor
I know I can get the complete kit from Gene but if I can find it used for way less what donor parts do I need to make sure and get??
Old Apr 22, 2009 | 11:23 PM
VettRick's Avatar
VettRick
Well, I'm not sure of the part numbers, or the technically correct names...there isn't much to it really.
Get the **** along with the retainer screw on the side. Then the shifter shaft and the "box" like base it sits in/is attached to. The shaft usually comes with the pivot box.
You might try a search for a "how to" on this swap. It might have pictures that show the shifter unit.
Old Apr 22, 2009 | 11:41 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
No additional parts needed compared to the old shifter.
Old Apr 23, 2009 | 12:25 AM
yaknow's Avatar
yaknow
To c6z06 shifter conversion questions
