Non-engine differences between Z06 and regular corvettes?
Old Apr 21, 2009 | 12:08 AM
Jack Daniels's Avatar
Jack Daniels
Default Non-engine differences between Z06 and regular corvettes?
I know the engine in the C5 Z06s is hopped up versus the regular corvettes, but can anyone summarize the differences for me other than the engine?
On a different note-----what changes did they make between the 2001 and 2002 z that added the 20hp?
Thanks a bunch.
Old Apr 21, 2009 | 01:46 AM
Blown 346's Avatar
Blown 346
The differences minus the engine.
The Z06 was lighter
A slight difference in body appeaance with the brake ducting
Suspension was different.
Gearing might be not sure.
Exhaust system
Differences between 01 and 02 for more power.
I believe the heads were different not positive.
Old Apr 21, 2009 | 09:10 AM
Mike Mercury's Avatar
Mike Mercury
yep; 6 speed manual tranny had different gearing for the Z06.
Old Apr 21, 2009 | 11:19 AM
ArKay99's Avatar
ArKay99
When you say regular corvettes, I'm assuming you are speaking of coupes and verts.
The years 1999 and 2000 introduced a new model, the FRC, or Fixed Roof Coupe. There were a few design differences that were different with the FRC, mostly to try and introduce an 'inexpensive' corvette. Surveys proved this to be an unattractive option for buyers so the FRC was set up a certain way to make it a more performance oriented version. The roof line was shortened to shave a little weight off and there was a chassis stiffener added right under the read window. It was fitted with the Z51 suspension which was the high performance suspension then. You could only order them with a black interior and a 6 speed manual trans.
Sales were pretty good for FRC's that year but dropped off in 2000. In order to boost sales they decided to further enhance the performance of the FRC by upgrading the suspension, adding the Z06 interior package, further lightening enhancements, a beefed up drivetrain, and a more powerful motor, the LS6.
The 405hp LS6 was put in in 2002. The 2002 LS6 had the same heads as the 2001 LS6 (243 castings), but the cam lift and duration was made larger and the compression went up a few 10ths. There were also some computer upgrades.
The 'beefier' driveline consisted of a larger torque tube, different gearing in the transmission, and shot-peened gears in the rear. All manual transmissions for all corvette C5's came with a 3.42:1 rear axle ratio.
We like to mod from there
Old Apr 21, 2009 | 12:16 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Here is press release on 2001 vettes, that talks about differences between regular vettes and Z06.
http://www.corvetteactioncenter.com/.../2001over.html
The Z06 has a different body, different transmission, stiffer suspension, and lighter weight than other corvette models.
Old Apr 21, 2009 | 02:14 PM
Humy's Avatar
Humy
I think the hoods are the same on all C5 or C5 Z06s aren't they?
Old Apr 21, 2009 | 02:32 PM
GOZ2FST's Avatar
GOZ2FST
Wasn't the glass used thinner to save weight? Shocks and sways were different too.
Old Apr 21, 2009 | 03:07 PM
vettelover84's Avatar
vettelover84
They are cooler.....
Old Apr 21, 2009 | 03:18 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
So what you are saying is that the FRC went from being the poor mans Vette to the rich mans Vette basically? LOL
Old Apr 21, 2009 | 03:42 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
All C5's have the same hood from Bowling Green with the exception of the 2004 CE Z06 which has a carbon fibre hood. It's the same shape as all C5 hoods and weighs in 10.6 lbs lighter than all other C5 hoods.
Old Apr 21, 2009 | 03:45 PM
ALEXAMES's Avatar
ALEXAMES
X2
Old Apr 21, 2009 | 03:46 PM
Humy's Avatar
Humy
Z06 = no fog lights, no topless option, and no sport seats - who came up with that idea
Old Apr 22, 2009 | 11:18 AM
Mike Mercury
ArKay99 is correct. The "poor mans" C5 turned out to be lighter & stiffer; and was the perfect platform for a more performance oriented C5.
Old Apr 22, 2009 | 01:37 PM
vettelover84
I know its not an option, but adding FOG lights is EASY, I know topless Z's are out there!! and my seats hold me fine!!!
Old Apr 22, 2009 | 02:03 PM
Glennm27's Avatar
Glennm27
The sport seats have the opening in the top of the seats allowing shoulder harnesses (real shoulder belts) to pass through.
It is against most track and racing organizations regulations for your harness belts to pass "around" the seats. They must pass "through" them......
So, it IS pretty strange to have the Z06 be the ONLY C5 that can not be ordered with the Sport seats from the factory...
Old Apr 22, 2009 | 03:15 PM
jedblanks's Avatar
jedblanks
Discovery HD Theater airs a show that details the building of a C6 Z06 in the factory (Modern Marvels?). It shows how the current Gen looks the same but is really a different car from the hydroformed frame to the lightweight rear hatch glass to the handbuilt and signed LS7.
Old Apr 22, 2009 | 08:14 PM
cbell3186's Avatar
cbell3186
It was called mega factories and was pretty awesome, great insight as to what really makes up a Z
To Non-engine differences between Z06 and regular corvettes?
Old Apr 22, 2009 | 09:58 PM
JDaniel's Avatar
JDaniel
I know. I was just makin a funny.
Old Apr 22, 2009 | 10:08 PM
tail_lights's Avatar
tail_lights
Tranny differences (I didn't see details posted yet) consisted of the MN6 for the regular Vette and the MN12 for the Z06. The MN12 gave the Z a more aggressive 1-3 gear and resulted in the gearing being closer to 3.90s even though the rear ratio stayed 3.42
Old Apr 23, 2009 | 06:39 AM
02 C5man's Avatar
02 C5man
Front fascia has front cutouts covered by inlet screens
Rear brake ducts
titanium cat back exhaust
wider wheels
thinner glass
less sound insulation
non removable roof
more aggressive gearing
stiffer suspension than Z51
non runflats
tire inflator kit (to make up for the non runflats)
no tire pressure monitors (can't use with fix a flat)
fixed mast antenna
no sport seat option
bigger airbox lid opening
lighter rims
transmission temp sensor
