Cruise Control Not Working?
Old Apr 21, 2009 | 02:19 AM
surges14's Avatar
surges14
Cruising
Default Cruise Control Not Working?
so my cruise isnt woking anyone know what might be going on.
i cant even remember that last time i used it
Old Apr 21, 2009 | 07:42 AM
biglite351's Avatar
biglite351
Not to be a jerk or anything... but are you just using it right? I do not think any car I have owned has had the same "process" in setting and using the cruise. Our Outback has a button on the dash that you have to push first and then a flappy paddle to set. The Vette you have to turn on, then push the set then adjust. My truck is different as well. Sometimes it takes me a minute to remember what the process is depending on the vehicle.
Old Apr 21, 2009 | 08:20 AM
poolboy's Avatar
poolboy
Have you checked the fuse? I don't remember which one it is, but the owners manual has a diagram - I know it is in the fuse box in the passenger's footwell area. Also you should pull the codes to see if any are being posted.
Old Apr 22, 2009 | 01:03 PM
cenzo's Avatar
cenzo
There's a switch on the brake pedal and one on the clutch pedal (if you have one) that disengages the cruise control. May need adjustment.
To Cruise Control Not Working?
