Installing APSIS Splash Guards..many pics..
Old Apr 21, 2009 | 02:28 AM
Gohard777's Avatar
Gohard777
Default Installing APSIS Splash Guards..many pics..
Just wanted to share with anybody who was interested in the APSIS Splash Guards. Did the install and took a lot of pictures.
Check the parts first, make sure that you are satisfied.
I didn't like the fact that the lower screw was to be mounted so high on the fender so I decided to change it so that it wouldn't be as noticed.
It turns out that it probably wouldn't of mattered, once you are committed to have them on, you will probably leave them on.
The new screw position was on a small angle, so I chamferred the new screw hole so it would mount flush.
The new hole is closer to the edge.
Take off the red tape, then reinstall it. I put a piece of tape over the egde to make it easier to peel back off again.
After a trial fit, I used this brush and paint to mark the location of the new screw hole. Touched the end of the brush to paint, ran it through the new hole in the guard, and there was my mark to drill.
Drill slowly, APSIS sent me screws and I used a 5/32's drill bit.
Now clean the area where the guard will go.
The hole is now more under the car than where APSIS had it.
I marked where the splash guard would go and where the adhesive promoter will go, with a felt pen. It's easily wiped off.
I then put the adhesive promoter on the fender.
I started the screw on the bottom with the red tape still on the guard, making sure Not to touch the guard to the car. Put the screw most of the way in.
Held up on the bottom of the guard, grabbed my piece of tape that I had put back on the red liner and gently pulled the liner up from the bottom as I kept the guard right against the fender and worked my way up so that there would be no gaps. Then tightened the bottom screw.
I wasn't satisfied with the gap at the upper end of the guard although it was small, that is why there are two more screws in the kit. I decided to use them. Remember, this requires one more hole in each side.
Hold the guard against the fender with one hand and drill the 5/32's hole in the hole provided in the splash guard.
Tighten this by hand, snug, not to tight.
See, No gaps.
The reason for the splash guards.........
This might be out there already from somebody but I figured it wouldn't hurt to put it out there anyway ............. bob
Old Apr 21, 2009 | 05:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Apr 21, 2009 | 07:04 AM
RSchleder's Avatar
RSchleder
How was the quality of the splash guards? Just wondering as I received a set of the early ones and returned them due to the finish not meeting my expectations.
Old Apr 21, 2009 | 07:54 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Nice job; Thanks for posting this to help the rest of us on the Forum!
Old Apr 21, 2009 | 07:58 AM
Dominic Toretto's Avatar
Dominic Toretto
Nice write up.
-Alex
Old Apr 21, 2009 | 09:59 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Nice work, can you post up some more pics a little further away from different angles? I'm interested in doing this
Old Apr 21, 2009 | 11:27 AM
tlc0706's Avatar
tlc0706
Good post....did wench when you were drilling holes though... They look good when mounted and like the new rims...
Old Apr 21, 2009 | 12:24 PM
1HOTVETT's Avatar
1HOTVETT
Looks good, what kind of wheels are those??
Old Apr 21, 2009 | 01:14 PM
Steve Alan's Avatar
Steve Alan
I just bought a set of 4 when I was at the Strictly Corvette show in Atlantic City over the weekend.
I got a call from them on Monday telling me they are back ordered on the rears for the C5. They have the fronts but wont have the rears till first week of May they said.
I seen them on a few of the cars up there and they do look nice. All the ones I seen were painted to match the car. I will probably do it that way. Hope there worth the $400.
Steve .
Old Apr 21, 2009 | 01:18 PM
JDaniel's Avatar
JDaniel
Would you mind posting a pic of the car at a distance with them installed so I can see what they make the entire car look like. Thanks.
Old Apr 21, 2009 | 01:37 PM
Nice writeup. They sure look good on the car.
Old Apr 21, 2009 | 01:47 PM
Gohard777's Avatar
Gohard777
First of all, let me thank you all for the comments.
Secondly, I would like to show you all some different angles and pics of the splash guards on the car, but, right now it is sleeting out here in Michigan and the car won't be out for a short time, maybe this weekend. I'll try, promise.
As for the quality of the splash guards, I was extremely happy with the fit and quality. There was a tiny mark at the tip on one of them, it looked like the paint was rubbed off about 3/8's of an inch and the white from the material, ( I believe fiberglass), was showing. A little flat black to touch that up when I get the chance, maybe a picture too.
As for the wheels, these are from Corvette Wheels. Jason Hunkler kept me informed as the rears were back-ordered, less than a week to get in. Total of two weeks from order to receiving them. Great service and a real nice look, almost went with the C-6 Z06 look, I thought that these looked more exotic, (expensive), and different from any around here. I will post more pictures when the weather breaks....soon.
Corvette-Wheels had a sale on these, $850.00 delivered to my door, they look real nice, the rears, 305/35/18 Nitto 555 RII Extremes, on 10.5x18's are five pounds heavier than the original run-craps on 9.5x18
Hope this answers your questions, if not, post or PM me .........bob.
Gohard, or don't go at all!
Old Apr 21, 2009 | 02:21 PM
jrose7004's Avatar
jrose7004
I like those guards, the way they look and what they do but lord they're pricey!
Old Apr 21, 2009 | 04:08 PM
sbadd99's Avatar
sbadd99
you can do it yourself pretty cheap, buy the C6-Z06 splash guard and trim it to fit they are about $19 ea, did mine about a year ago front and back
Old Apr 21, 2009 | 06:46 PM
doug doo wop's Avatar
doug doo wop
Steve .
I hope they look good on mine too; I bought the set on display at the show Sunday and will have them painted mag red. If you saw Kens yellow C5, he had them and they had the 3M protection on them to keep the paint from chipping.
Old Apr 21, 2009 | 07:27 PM
dobewillie's Avatar
dobewillie
very nice
Old Apr 21, 2009 | 08:41 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I have not made up my mind that this is a mod I want but
you did a nice job.
Old Apr 21, 2009 | 11:27 PM
Choreo's Avatar
Choreo
Here are some pics of mine in this post...
http://forums.corvetteforum.com/c5-g...-big-pics.html
Old Apr 21, 2009 | 11:41 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
you did a nice job.
After a planned paint job someday, guards will do on ! Thanks!
To Installing APSIS Splash Guards..many pics..
