Suede Wrapped Door Panels
Old Apr 22, 2009 | 04:03 AM
Z06Fanatic's Avatar
Z06Fanatic
Default Suede Wrapped Door Panels
I'm getting the idea of going to a fabric place to buy a roll of Black Suede to cover my Door Panels. Wondering how it would look. But first of all...possible?
Would it be as simple as removing the door panel, spraying it with fabric glue (that will stick to both the suede and the door panel), and rubbing the suede out free of any creases, folding it to back side of the panel for a clean OEM finish? Hope this makes sense.
Maybe if I do try it, I'll start with something like the center arm rest
Old Apr 22, 2009 | 06:45 AM
WKMCD's Avatar
WKMCD
Check with Chip (WILLFULONE). He did the lower panels on his doors.
Old Apr 22, 2009 | 08:08 AM
dreamscometrue's Avatar
dreamscometrue
I did the passenger glove compartment and driver knee bolster under the steering wheel. I took off the stock pieces and sprayed with contact glue a little section at a time and placed the black suede over the glue and streched and sprayed more as I went a long. Suede doesn't stretch much like leather and you have to be real careful with the finished side of the suede to keep it nice. If you use too much glue it will show through. I would think the top section of the door would be difficult with all the corners and tight bends to make. You may have to make seams to help minimize wrinkles. I don't have any pics right now but I'll try to get some tonight after work.
Old Apr 22, 2009 | 08:26 AM
Lowcash's Avatar
Lowcash
I saw a set this weekend and it made me consider tackling the mod this winter.
Old Apr 22, 2009 | 08:37 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
It is not that hard, however the door panel is two pieces that are plastic welded together so you have to crack your door in half.
Use this to put the two door pieces back to gether
Peace
Chip
__________________
..................Click for
Old Apr 22, 2009 | 08:40 AM
WKMCD's Avatar
WKMCD
Look at Alcantara -aka Microsuede. It looks better much longer and cleans much easier than suede. I ordered my DSV steering wheel with Alcantara in the grip area because of those reasons.
Old Apr 23, 2009 | 02:43 AM
Z06Fanatic's Avatar
Z06Fanatic
Default Sweet!
Thanks everyone! Now I know it can be done. Now I just need to stop working so much and make the time to do this
Old Apr 23, 2009 | 08:46 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
nice
Old Apr 23, 2009 | 10:50 AM
Chip's car looks great with that blue suede added. If the OP decides to do the change, please document what you did and post it up. Would be interesting to see the process from start to finish.
Old Apr 24, 2009 | 01:00 AM
2000lambovette's Avatar
2000lambovette
I started out doing CF but did not like the way it turned out on the lower doors so covered them in black suede, i also did the window pillars, console, glovebox, and radio bezel. When I switch to black carpet instead of red I will swap out the black suede with purple.
http://strobelvette.webs.com/
P.S Chip your interior looks awesome!
Old Apr 24, 2009 | 01:18 AM
Choreo's Avatar
Choreo
I did my lower doors and bezels with carbon fiber leather (VE did the pull handles and arm rests). I would think the upper doors would be impossible to do in a single-piece of leather...
Old Apr 24, 2009 | 01:20 AM
2000lambovette
That looks very nice.
Old Apr 24, 2009 | 09:00 AM
bucwheat's Avatar
bucwheat
Why don't you just spray dye them ,there is some excellent dye's out there ,very tough.
To Suede Wrapped Door Panels
