Need Help With Vararam!
Old Apr 22, 2009 | 09:41 AM
HUSKER-Z's Avatar
HUSKER-Z
Default Need Help With Vararam!
Guys,
got a 03 Z, used with a Vararam installed into it already. Need help w/ a few things...
How do you get the cowl (the part with the VARARAM sticker) off to change/clean the filter? (take the entire airtube off, or just take off the wiring harness, etc?)
Also, noticed the sealing/ weather stripping foam has started to go ka-put. Any ideas how to keep this from happening?
Thanks for any tips guys and gals!!
dk
Old Apr 22, 2009 | 09:51 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
You should be able to unclamp the red coupler and then the tabs on the side of the airbox and lift the lid off
Clean the filter (if it is a green filter, replace it)
http://www.customcorvetteaccessories...mintakec5.html
Lightly oil it and replace.
Might as well clean your MAF while you are at it.
If you need to replace the seals, use Frostking 3/16 weather stripping. You can get it at Lowes or HD for about 3 bucks
Peace
Chip
__________________
..................Click for
Old Apr 22, 2009 | 11:44 AM
HUSKER-Z's Avatar
HUSKER-Z
It's a summbish getting that thing out. may have to get some short screw driver. I thought the green filters were cleanable?? Guess not?? Thanks again!!
To Need Help With Vararam!
