A/C problems
Old Apr 23, 2009 | 07:38 PM
wrrn73's Avatar
wrrn73
Default A/C problems
On my 1999 the A/C compressor is running and the pressures are where they are supposed to be but yet it doesn't blow cold. Where do I look next?
Old Apr 24, 2009 | 08:44 PM
wrrn73's Avatar
wrrn73
Can't believe nobody has had this same problem. Maybe just doesn't want to share info?
Old Apr 24, 2009 | 09:05 PM
Bill Dearborn's Avatar
Bill Dearborn
Use the DIC to run the codes on the car. You could have an actuator issue. By the way you would probably gotten better response if you posted in the Technical Section. It might be better to post there once you have the codes. To get the codes push and hold the options button and while holding the button push the fuel button 4 times. The car will go into diagnostic mode and display the codes on the DIC.
Bill
Old Apr 25, 2009 | 07:23 AM
wrrn73's Avatar
wrrn73
OK thanks. I will try that.
To A/C problems
