Seat foam
Old Apr 24, 2009 | 08:42 AM
ter's Avatar
ter
Default Seat foam
My seat foam went south at about 30K miles. So I need to replace it, but I am leery of using GM foam, because the original stuff was so crappy. Is there a better aftermarket source, or should I go with the OEM stuff? Thanks.
Old Apr 24, 2009 | 08:45 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I know VE offers seat foam and when I'm ready for my new skins, I will probably replace the foam as well. I was going to ask them if it was GM foam or something better....
Old Apr 24, 2009 | 12:24 PM
blkvette98's Avatar
blkvette98
Default Seat Foam
I bought mine from VE. Seems to be better quality than standard GM foam and was considerably cheaper. Sits better than the old stuff!
Old Apr 24, 2009 | 12:47 PM
2000lambovette's Avatar
2000lambovette
I have aftermarket seats but what I did should work on stocks as well. I bought thick memory foam and used an electric bread knife to cut it to match the shape of what I was replacing. It is so comfortable and should hold up for a long time.
Old Apr 24, 2009 | 01:52 PM
ter's Avatar
ter
Sorry I don't know who/what VE is. I tried a search and got nothing. Thanks.
Old Apr 24, 2009 | 01:54 PM
MSG C5's Avatar
MSG C5
VE = Vette Essentials.
Old Apr 24, 2009 | 02:04 PM
When I put the leather interior from Vette Essentials in mine, I also replaced the seat foam - and got it from them. Not sure where they get it from, but it is a good quality product.
Old Apr 24, 2009 | 02:15 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I'm not sure about anyone else's experience, but the way the foam sits on the wires, over the rails is what caused my seats to feel "flatter"... it kind cuts into the foam. I used my original foam and just had it reinforced under the bottom and it's fine.
Old Apr 24, 2009 | 04:32 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The trick is to use a piece of burlap glued to the bottom of the foam or a piece of mat used under you house carpet.
This will stop the nagging seat sag.
Old Apr 24, 2009 | 04:47 PM
tigers123's Avatar
tigers123
Just had my seats redone. The wire was starting to cut the foam like a cheese slicer. My uhpolsterer put canvas between wire and foam. Also has anybody noticed the excessive wear on the bolsters? I put extra foam under bolster area and bought bolster bras from mid america to use when I'm driving the car a lot. They just slip on like a fat girls tank top. As expensive as leather covers are I thought it might help.
To Seat foam
