Quick Question!!!
Old Apr 24, 2009 | 12:29 PM
a1231212's Avatar
a1231212
Default Quick Question!!!
last night i was at a bonfire and was using my vette to play some music (i have a pretty nice system). long story short, the battery died (i know, epic failure), and i started it by having my buddies push the car and slowly releasing the clutch while putting on gas ( i have a manual)
...anyways, afterwords, the car said "reduced engine power" and at full throttle was only going about 8 mph, and my check engine light was on. We let it sit for a bout 15 minutes and then turned it off, then started it about 15 minutes after that. When I did, my car was idling at a much lower rpm then normal (about 500), and when i revved up, the rpm would then go down below the normal idle rpm and almost die (i could feel the car shaking a little).
So I made it home, then turned on my car this morning, and its not as low idle rpm as last night, but its still a little bit lower than normal.
MY question is, is it the battery that was weak and is getting better?
I thought that maybe because I had my car tuned, starting the car the way i did might have re-set the computer, so the tune is off.
What do you guys think, and what should i do?
(if i need to get it re-tuned, its free where i go and i need to anyways because im installing long tubes this sunday)
thanks!!!
Old Apr 24, 2009 | 01:24 PM
02MillenniumVette's Avatar
02MillenniumVette
Is it the original battery? Why didnt you just have them jump start it?
Old Apr 24, 2009 | 01:45 PM
itzza427's Avatar
itzza427
Have You recharged the battery with a charger?? I've read that it is Very hard on modern alternators when trying to recharge a dead battery (builds a LOT of heat in them),,so it may very well not have a full charge yet. Put it on a charger ,,bring it up to a full charge,,THEN check it out!!
Old Apr 24, 2009 | 05:16 PM
a1231212's Avatar
a1231212
will do thanks!
so if i do that it should be the way it was before?
Old Apr 24, 2009 | 05:17 PM
a1231212's Avatar
a1231212
it is the original battery, and it was really late at night and no one had cables
Old Apr 24, 2009 | 07:39 PM
02MillenniumVette
As itzza427 said, I would try putting the battery on a charger and see if it takes a charge. If not then you need a new battery obviously.
dobewillie's Avatar
dobewillie
good luck with a quick fix
Old Apr 26, 2009 | 03:19 PM
a1231212's Avatar
a1231212
will do, ill let u know how it goes, thanks
To Quick Question!!!
