C5 Alternator?
Old Apr 25, 2009 | 05:53 PM
02impactblue's Avatar
02impactblue
Default C5 Alternator?
I just received a new alternator from Gene Culley and it looks different from my original alternator. It has a made in France label and the pulley is significantly different then the original one in my car. The new alternator has a longer snout protruding from the pulley assembly. It physically looks like it will fit but I'm having doubt's this is the right part. Is this a new style? Has anyone ordered an alternator recently, and if so, did it look like the one pictured?
The car is a 2002 Z06 and the part I received was 10316182
Old Apr 25, 2009 | 06:08 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The reason the pully looks different is because they added a clutch to the pully, Why did they do this you ask?
There have been some issues with vibration when the wheel was turned far right or left and they found that adding a clutch to the alt pully got rid of the vibration.
There you have it.
Same unit I have on my 2002...
Old Apr 25, 2009 | 07:54 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
my alt has the same set-up
Old Apr 25, 2009 | 10:52 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I believe the clutch pulley was a feature found on later model automatic transmission cars.
Old Apr 26, 2009 | 12:42 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
There you have it.
I had one like that on mine but it interferred with my new FLIP-DRIVE set-up for the SuperCharger and I had to have it removed and a standard pulley put on
If you do not like the CLUTCH Style then you can go to the Alternator shop and have them swap it out - you will need a special tool to remove the clutch style - I know because I watched the guy remove it and explained about the tool he had to buy especially for them
Thanks,Matt
To C5 Alternator?
