C5 drag radials questions...
Old Apr 28, 2009 | 10:15 PM
tommie's Avatar
tommie
Default C5 drag radials questions...
Need to get some Drag Radials for the C5, looking at the Nitto 555R's, I have the stock thinspokes 18X9.5" with 275/40/18 tires.
What size should I get in the 555R's? closest that I saw was the 285/35/18.
Would this be the best fit? and would the diameter be close enough that the BCM/ECM would not throw any codes for traction control or ABS?
These should hook up with 388 rwhp/383 rwtq right?
Where is the cheapest place to buy these? I just need carry out, I can mount and balance at work.
Trying to set aside some $$ for this, hope to be able to pick some up soon, ( I just got a side job that should cover most of the $$ I hope) the 555's that are on there now are not hooking up.
pick I found on CF of some 285/35/18 nitto 555r's on thinspokes...
Old Apr 28, 2009 | 10:57 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
Ive tried a few DRs and have found that MTs and BFGs are a better tire. I have MTs now and you would not believe how they hook. Only my $.02 dont go 555s
Old Apr 28, 2009 | 11:07 PM
EllisJuan350's Avatar
EllisJuan350
****to's are good for a DD car that has a decent amount of power to drive around on daily. They are not any good(in regards to other DR's) at the track. They are more of a very sticky street tire. If you want something to hook that you dont have to worry about, Go with a MT....You wont regret it.
Old Apr 28, 2009 | 11:24 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
nittos' drag radial is crappy compared to MT or BFG. personally, i had nitto first and they were horrible. Then i got BFG and it was a huge improvement!!! i loved those tires!!! hooked my 500+rwhp car no problem. I hear the Mickey Thompsons are a hell of a lot better then the BFG even.
as for your tire size, i bet you could go 305 even on that 9.5" rim. however, its not safe if you plan on hitting corners hard.
Aj
Old Apr 29, 2009 | 12:28 AM
S.U. Vette's Avatar
S.U. Vette
These are 555's with 370rwhp and already partially warmed.
Even at 40mph I can break them free quite easily.
Click for video
Old Apr 29, 2009 | 09:16 AM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
do you have a stock rear end? DR's will be a lot of stress on your rear
Old Apr 29, 2009 | 09:51 AM
warren s's Avatar
warren s
You get what you pay for. I had very good results on my car with the Nittos. Its a mid 12 second car, and they need to be really smoked up to work at all.
To C5 drag radials questions...
