Someone reversed into me in the parking garage at about 4-5 mph. Looks like my CCW classic wheels bore the brunt of the impact and actually caused a round shaped cut on his van!
Damages:
Alignment is off
Wheel lip is damaged and wheel is slightly bent.
Scratches of the fender
I went to the body shop and they are saying that they *might* be able to buff out the scratches and that my wide tires cushioned the impact. Also mentioned that the fiber body is supposed to flex and that also helped contain the damages.
Since the alignment is off, i am worried what else it may have damaged internally. Any ideas on what else could be damaged and where should I take my car to get that checked out? The bodyshop did not hoist the car.
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Originally Posted by RSchleder
Did the "bumper" leave you a note with his/her info?
The OP already mentioned that it was a van and that it was a male driver. So he must have either been in the car when it happened or the perp left a note (hopefully).
He's a co-worker so I am getting it repaired privately and he's footing the bill. So far the paint damage seems to be just a buffing issue and the dealership says that it just needs an alignment along with the Wheel fixed. I'll be visiting Steve on 20th to get my wheel checked out tomorrow.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Originally Posted by boomie1
He reversed into me while i was in it
Turned out its not as bad as I had thought! Whew!
Good news, as said have it checked out, fixed up then
