Lift/jack stands fall ever??
No idea how or why so many would try to lower the car on thier own...i want this done to my car badly but I figure, since I hear so many have trouble turning the bolts at times, that wrenching of the car would really put into risk of it collapsing. Youd think this would happen alot...but maybe im wrong....
Hell im worried now just to remove the wheels and change the rotors at this point.... Are the puck points on the car really balanced when all are engaged or does it "look and feel" unstable up there? (for those that had it up there....
I asked in the past about which floor jacks and stands to buy...as they vary hugely....so im confused
Here's a 4-post lift failure.
http://forums.corvetteforum.com/c5-t...gs-images.html
One guy posted pics of his lift failure where his C3 collapsed onto his C4.
Here's an unfortunate jacking accident posted on here a while back.
I was jacking my C5 years ago and first put the rear crossmember up on jack stands. I then jacked the front to put that on stands but something felt funny when I let it down on the front stands.
When I looked at the back stands I was horrified to see that the car had moved backward when I had jacked the front, causing the rear stands to tilt back onto the back legs which consisted of about 1/8" thick steel. The stands were tilted back on those thin slivers of metal at about 60 degrees. Probably another couple of degrees and they would have toppled backwards with the car falling on them, causing major damage.
A good breeze could have caused the car to move enough to fall so, as badly as I wanted a picture of it, I quickly moved the jack to the back of the car and lifted the car from the center of the member. When I did that, the stands stayed perfectly balanced on their back legs for a few seconds and then slowly rotated forward back onto all feet. Whew!
Now I use a 4-post lift and am still extremely careful when under it.
Plus, one must be careful just how much one pulls on a wrench in any one direction that might upset the car....common sense....
I also leave the jack in place.
Pay no attention to the grey haired gremlin....
Probably very safe with two wheels up, or on ramps, but I try and do any of the little minor things Im able to do wiht only one wheel up (oil, brakes) at a time (just nervous).
Also when you use a floor jack and already have one end up in the air on jack stands, don't forget to check the alignment of the rear wheels on your floor jack. They need to be straight so the jack is free to move when you use it. I have seen several people put one end up on jack stands and literally pull the car off because the jack could not move and the car was pulled backwards.
Be careful out there
Peace
Chip
Chris
The funny part was when I was just starting to jack it up I put 3 or 4 pieces of wood under one tire. I freaked the neighbor out across the street so bad he was bringing me a pair of jack stands. I explained I was just getting it up enough to get the jack under the rear cross member. He looked relieved.
Don't try it at home.
Thats what i do too, i have 3 jacks.
