Nassau Blue Paint Code
Old Apr 30, 2009 | 03:12 PM
VetteStir's Avatar
VetteStir
Default Nassau Blue Paint Code
Does anyone know the paint code for Nassau Blue? I just took a piece to the body shop and gave them the paint code 23 and the part came back too dark.
Old Apr 30, 2009 | 03:20 PM
BAMbrick's Avatar
BAMbrick
Old Apr 30, 2009 | 03:22 PM
vette.mix's Avatar
vette.mix
My touch up bottle has GM code 23
also on the bottle:
A4900-290
A28-1-02
Paint Ext.tu Nassau Blue, 97-00
Old Apr 30, 2009 | 03:48 PM
WGreen's Avatar
WGreen
Cruise-In I Veteran
As I recall when I had some pieces painted the painter wanted the last number on the sticker in the glove box which was U348D
Old Apr 30, 2009 | 04:26 PM
505HPZ06's Avatar
505HPZ06
Default Paint Code 23
When you take the part you want painted to your body shop make sure you take the car as well. With a good body shop they will have a light that will help them match your perfect shade of Nassau Blue. My body guy did that on my vehicle. You would be amazed how different the color can come out without using a special paint light.
Old Apr 30, 2009 | 05:17 PM
travelingypsye's Avatar
travelingypsye
23 is the code & it is really called "bright blue metalic" 97-99 & nassau blue for 2000.
Old Apr 30, 2009 | 05:20 PM
vette.mix's Avatar
vette.mix
Christian Auto Body
114 Lafayette Ave
Laurel, MD 20707
410-290-3800
This shop could be a bit far for you but I'm sure Glen, who is a friend on mine could match it up. He painted my wifes Jag and I'm still impressed the way it looks, when its comes time to paint the Vet he will do it. Tell him Martin sent you.
Old Apr 30, 2009 | 05:22 PM
MYRagtop's Avatar
MYRagtop
This should just about cover it.
http://www.corvettepaintcodes.com/
Old Apr 30, 2009 | 07:25 PM
VetteStir's Avatar
VetteStir
I saw this site and as stated above, it is listed as bright blue metallic. After a little research I found out that there are actually three different blues under under GM code23. WONDERFUL! I would have thought the body shop would have brought this up.
Old May 1, 2009 | 09:42 AM
VetteStir's Avatar
VetteStir
Originally Posted by vette.mix
Christian Auto Body
114 Lafayette Ave
Laurel, MD 20707
410-290-3800
Thanks for the info. I've had some bad experiences with body shops!
To Nassau Blue Paint Code
