Store it Or Drive it
Old May 3, 2009 | 05:33 AM
vetter79's Avatar
vetter79
Originally Posted by 00 Rooster
I store mine for the winter and leave the trickle charger on for about 6 months. Works just fine.
Good luck!
5-6 mos. layup time here also. Never had any A/C issues. Hook charger to Batt.!
Old May 3, 2009 | 10:22 AM
Use the trickle charger and let the neighbor drive it every couple of weeks. That is as long as you trust him with the car.
Old May 3, 2009 | 10:26 AM
rws.1's Avatar
rws.1
Put it on a bettery float charger.....
For 6 months there is not much else you need to do.
Old May 3, 2009 | 10:30 AM
R Devil's Avatar
R Devil
It'll be fine.
Old May 3, 2009 | 07:58 PM
FlemFlamMan's Avatar
FlemFlamMan
4th Gear
Default Thanks Everybody
Originally Posted by R Devil
It'll be fine.
Thanks everybody for all the good advise. I was given a Vector VEC080 Float Mode Charger/Maintainer. I've decided to add the Stabil, remove cable, connect the Vector, over inflate the tires and a box of mothballs under the hood and hope for the best.
Old May 3, 2009 | 08:19 PM
bencini231's Avatar
bencini231
I say store it and you can leave the trickle charger hooked up. Also you could have you neighbor come by to check on it if you wanted.
Old May 3, 2009 | 08:29 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Originally Posted by pentavolvo
stabli in the gas, overinflate tires, and disconnect battery
I've stored my car for 8 years and disconnect the negative battery terminal. It has always started the first time in the spring after sitting for nearly 6 months.
Old May 5, 2009 | 08:36 AM
RSchleder's Avatar
RSchleder
We leave Iowa every winter for 3-4 months. I use a battery tender and when I return, it fires right up and down the road I go! It'll be fine and you won't have to worry about it!
Old May 5, 2009 | 12:04 PM
SavPrato's Avatar
SavPrato
Originally Posted by 1998whitecoupe-a4
man, there is no way I would let anyone drive it.
mine is stored, I only drive it on nice dry,clear days.
no rain or snow - ever!!!!!
I use a trickle charger and never had any issues, but mine gets hooked up to the battery.
Old May 5, 2009 | 12:44 PM
HeadsUp's Avatar
HeadsUp
Originally Posted by Bill K
I don't see why members don't let people that they trust to drive the car, It isn't like it is a 100,000 car, If worried about getting into an accident.. That is why we pay insurance... I have let a number of people drive my car and have never worried about it as long as you trust them...
Comon guys it is a 18,000 car, Heck a new Honda cost more than that....
Can I borrow your car? Mine is in the shop due to someone borrowing it.
Old May 5, 2009 | 01:00 PM
rebelheart's Avatar
rebelheart
The worse thing you can do is let a car of any sort sit and rot! Have a trusted friend fire it up and drive it a bit,circulate those lubes and dry out any moisture!
Old May 5, 2009 | 02:43 PM
rboineau's Avatar
rboineau
Default Store it or drive it
Storing it with proper precautions--battery tender/minder, fresh oil in the car and circulated, on jackstands with wheels off if you're really ****, is probably best. If you do let the man drive it, PLEASE make sure he knows how very low and easily damaged those cars are if he goes up an angled driveway, hits a pothole or curb, etc. It would make me very nervous to let someone not familiar with C5s just take off in mine. Good luck
Old May 5, 2009 | 04:59 PM
  #33
Jistari's Avatar
Jistari
Yes, but you are not likely to pull a honda into a parking spot with a bumper and destroy the front end or air damn, nor are you likely to paralell park a honda and road rash the rims, nor are you likely to park a honda in a spot with a vacant spot in front of you and come back to see that a women (sorry, could be any driver) has backed an SUV over your front end, nor are you likely to make any number of a myriad of mistakes that involve "acceleration quite outside the normal driving experience" in a honda. . . .you get the idea.
BTW, Ive let a bunch of people drive my car but I have been aboard every time. Wouldnt think of just handing the keys to someone who hasnt had a check ride, or letting just about anyone drive it without me on a regular basis.
For the OP: Dont sweat it. Put it on a triclke charger and go with a clear head. If you are worried about the car, take the battery out and leave that on a trickel charger (just make sure you have theft lock disabled on your radio (not enabled by default) or you know the code before you leave it without a battery, so you can enter it when you put the battery back in). Other than that, you reset the clock, radio stations and seat/memory positions. The PCM will relearn the mixture and whatnot after 40 miles I think (this is pretty transparent to you, the car runs, it just runs better at wot after the pcm has that much data). Although I didnt notice how long you are gonna be gone for, six months and under is nothing. You want to be extra careful, drive it up onto a set of wheel savers (if you are worrying about flatsideing the wheels).
Old May 7, 2009 | 03:45 AM
  #34
FlemFlamMan
4th Gear
Bro, what are wheel savers and where do you get them?
Old May 7, 2009 | 04:09 AM
  #35
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Seafoam in a full tank of gas, Battery Tender for the battery and in 6 months.
Old May 7, 2009 | 05:04 AM
  #36
Jistari's Avatar
Jistari
They are like pads that you park on. The bottom is flat and the top is cup shaped (same size as tire). I dont know if I would bother with them, just read a few posts on storing long term and guys mentioned them. Think I saw them on one of the vette accessory sites, they were red plastic and about the size of a floor tile.
Old May 7, 2009 | 07:10 AM
  #37
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Option #1!
Thanks,Matt
