[Z06] headers
Old May 6, 2009 | 10:11 PM
camaroracer91's Avatar
camaroracer91
Default headers
OK im new to vettes, im a camaro guy and after doing headers on my camaro i started running all sort of lean and then rich codes even after headers, im probably going to get a z06, if I do headers do you guys have any problems, or is there anything else that usually throws codes that I should look out for? thanks
Old May 6, 2009 | 10:18 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
If your going to spend the money on headers, spend the money on a tune. youll get more power and your car will run the way it should.
Old May 7, 2009 | 07:16 PM
camaroracer91
well i have a tune on my camaro and its still hasnt run good since header install
Old May 7, 2009 | 08:42 PM
71corv's Avatar
71corv
St. Jude Donor '08
Have headers on my 02 Z06 along with a dyno tune. No problems at all. Look for a tuner familiar with the Corvette. Only problem you will have at the beginning is the 02 sensors. Get the Z06 and enjoy. You will not regret it.
Gene
Old May 7, 2009 | 08:48 PM
Goody's Avatar
Goody
Gene
I too have headers and cats installed. Also paid a pro for a quality tune and my car does not throw codes and idles like stock.
Also, a good time to have some codes removed from the system so they don't show up (1-4 Shift light) if you have the CAGS defeated.
Old May 7, 2009 | 09:46 PM
GARY2004Z06's Avatar
GARY2004Z06
I would strongly suggest 1 7/8 " American Racing Headers since they are found on the fastest 346 H/C Z06 and the fastest bolt-on only Z06.
Good luck.
Old May 9, 2009 | 01:55 PM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
If your only doing bolt ons I would say go !-3/4 If you doing a head/cam or FI I would go !-7/8's. And get a tune from a reputable tuner.
Old May 9, 2009 | 02:22 PM
sami85L98's Avatar
sami85L98
I would go all out 1 7/8 with 3" catted X pipe and spend extra cash and get ARH system, callaway honker CAI and definetly tune, i drove 2-3k miles after headers, Vararam and 160 stat with no problems, except P0420/P0430 codes which dont effect performance and they are for rear O2 sensors which u can disable even while driving car.
Now got i Diablo tuner, and my car was running lean so added some fuel and set FAN settings and iam good to go.
Old May 9, 2009 | 08:44 PM
tlc0706's Avatar
tlc0706
Although there are a lot of folks that do headers and drive without a tune, it's really not getting the benefit of your money already invested. You will get some codes. Tuners such as ECS and Chuck Cow offer mail-in tunes if a qualified Corvette shop is not close. There always has been a positive response here on their work. Put em on, get it tuned and have fun.........
Tom
PS...Header manufacturers will help on size, such as the one that already posted here.
Old May 10, 2009 | 07:19 PM
camaroracer91
what about obx headers are they any good
Old May 10, 2009 | 07:27 PM
GARY2004Z06
C5 Z06 External Bolt On Times (stock long-block)
1--10.890@125.06--1.465--GARY2004Z06--'04 12/08-VR CAI, DRs, ARH LTs, Clutch, Gears
C5 Z06 External/Internal Bolt On times (stock cubes, n/a, cams, h/c, all bolt ons)
1---9.985 @ 138.80--1.428 --robz ---------'03 04/08 -----H/C, ET ST, Gears
Sorry to repeat myself.
Old May 10, 2009 | 09:03 PM
camaroracer91
but thats like a grand difference whats honestly the difference going to be in hp
Old May 10, 2009 | 09:09 PM
zapp109's Avatar
zapp109
Im a cheapass and i got the 1 7/8 ARH with 3 " X no cats.. Spend the money for a good product that wont fall apart. Fit perfect. If you want cheap dont get a vette.
Old May 11, 2009 | 11:42 PM
Irieone's Z06'n it's Avatar
Irieone's Z06'n it
I have had the OBX Headers on my Z since Oct. of last year, and they havent fallen apart yet!. The fit was good, only issue on the install, was the tunnel plate. Should I add, its my Daily Driver Too. The Hp gains where great, considering the headers were only 650 dolars.
Old May 12, 2009 | 08:47 PM
GARY2004Z06
My bolt-on package made 382 HP on a conservative Mustang dyno. (This is approximately equivalent to 420 HP on a Dynojet.) Most bolt-ons are in the 385 HP(Dynojet) or slightly better range.
Good luck with whatever route you choose.
Old May 17, 2009 | 05:48 AM
whiplash306's Avatar
whiplash306
Watch for the p0133 and p0135 codes (lots of posts concerning these two) as well with the addition of aftermarket long tubes. Those are the "heater" codes involving the front O2 sensors. Pain in the BUTT codes that also do not affect driveability, but are irritating in that they illuminate a CEL...
Old May 17, 2009 | 06:04 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Then you have worthless tuner and he should he fired.
If/when you do buy a Corvette, you should do the same as any engine (be it Honda or Ferrari) when you upgrade make sure the tune is set accordingly.
To headers
Old May 17, 2009 | 12:02 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Based on your planned mods - I would go with the 1 3/4" LT headers. Lots of good options for the C5. I use ARH and am very happy. The tune will maximize the performance gains, ensure stock like idle and no codes. Complete your Profile so we can recommend some good tuners in your area.
Old May 17, 2009 | 12:07 PM
camaroracer91
is tune time performance good in new jersey
Old May 17, 2009 | 12:09 PM
Gray Ghost GS
Never heard of them. If you're looking for a good Corvette tuner in the NJ area - check out our forum vendors: ECS, Cartek and Vette Doctors (I believe there are a couple others too).
