Antenna Adapter?
Old May 7, 2009 | 06:51 AM
hayman's Avatar
hayman
Default Antenna Adapter?
Yes, I did do a search. Yes, I am aware there is an audio section. But the way I see it is maybe someone had this problem and has the answer but does not visit to the audio section.
I have a 99 vert and replaced the Bose radio with the JVC KD-NX5000. I have no radio reception and I am sure the antenna is plugged in. Question; is there a difference between the Bose antenna plug to the JVC plug that I need an adapter? If so which adapter do I need?
Old May 7, 2009 | 07:56 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Originally Posted by hayman
yes, i did do a search. Yes, i am aware there is an audio section. But the way i see it is maybe someone had this problem and has the answer but does not visit to the audio section.
I have a 99 vert and replaced the bose radio with the jvc kd-nx5000. I have no radio reception and i am sure the antenna is plugged in. Question; is there a difference between the bose antenna plug to the jvc plug that i need an adapter? If so which adapter do i need?
metra 40-gm 10
Old May 7, 2009 | 12:13 PM
hayman's Avatar
hayman
Originally Posted by c5 BearsFan
metra 40-gm 10
Thanks, Just picked one up and will install this weekend.
Old May 7, 2009 | 07:41 PM
hayman's Avatar
hayman
Turns out the installer had the adapter installed but was either broke on install or was defective from manufacturer. I now have am and fm…
Life is getting better. Now I need to get the itouch adapter and Bluetooth.
To Antenna Adapter?
