Codes
Old May 7, 2009 | 08:44 AM
Lancejoker's Avatar
Lancejoker
Default Codes
Can someone decipher these for me. I decided to check the history this morning and these were listed.
PO 492 H C
U1016 H
U1096 H
BO367 H
Thanks guys
Old May 7, 2009 | 09:18 AM
VeroWing's Avatar
VeroWing
Here you go.
http://www.stengel.net/diccodes.htm
Old May 7, 2009 | 10:20 AM
Lancejoker's Avatar
Lancejoker
Hmm,first code isn't listed. 2nd and 3rd seem to be a communication issue and the fourth is a left actuator open. Anyone have any insight on these and what the problem/solution might be.
Old May 7, 2009 | 10:34 AM
VeroWing's Avatar
VeroWing
Anything with an H is a past code. I would go back and check to see if you have the correct number on the first one.
Old May 7, 2009 | 10:37 AM
VeroWing's Avatar
VeroWing
Found this.
http://www.gearchatter.com/viewtopic10679.php
Old May 7, 2009 | 10:42 AM
Lancejoker's Avatar
Lancejoker
Thanks. I wrote them down as they came across but I will double check after work tonight.
To Codes
