Rocking and rolling C5 seats....
Old May 8, 2009 | 11:44 PM
Jesse Asis's Avatar
Jesse Asis
Default Rocking and rolling C5 seats....
Plan A, Fellow C5 Drivers, rumor has it that after a few years the seats of a C5 have a tendency to rock (1/4 movement forward/backward). This is due to a poor design of the auger track block isolator. Well my driver side seat was real bad, passenger not any better. I found this in the web searching for a solution. I followed it to the T, and now I am the proud owner of solid seats... hats off to the creator of this procedure, I take no credit but give this man a lot of it.. Now working on getting new leather skins for the worn out driver seat.. Plan B..
Here is the link:
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
Old May 8, 2009 | 11:48 PM
happa's Avatar
happa
Yea I did that too, very helpful
Old May 9, 2009 | 12:32 AM
cbell3186's Avatar
cbell3186
nice post, I was just driving around the other day and was curious about that.....thanks......
Old May 9, 2009 | 04:15 AM
Jesse Asis's Avatar
Jesse Asis
Yea, mine was so bad when I accelerated the I movement was just enough to have the clutch foot engage and jump off the line, I could truely say "Offcier it was the car not me!!!". Plus I couldn't stand hearing my passenger say, "hey what the heck is wrong with your seat here". I used 8 nylon washers from Home Depot at $ 0.12 cents each. You do have to file one down for each block to fit snuggly, but it was a breeze.. These forum are the best place for concerned Vette owners and it is very helpful to share these fixes so other Vette owners won't have to re-invent the wheel. Ride safe and look good doing it. Jesse
Old May 10, 2009 | 01:17 AM
Jesse - Thanks for posting up that link - it has been on here before, but it has been a long time. Always good to have a reminder of procedures that work.
Old May 10, 2009 | 01:23 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Worked great for me. My passenger side didn't need it. And I did find more than enough change to pay for the washers.
Old May 10, 2009 | 04:52 AM
Jesse Asis's Avatar
Jesse Asis
Thanks guys, Corvette Forum has great members, in fact I haven't met a Vette owner that was negative. It must be owning a wonderful sexy vehicle that stirs the emotions... I"ll stop now, or I may have to turn in my man card... How about those Raiders
Old May 10, 2009 | 10:39 AM
MagRedConv's Avatar
MagRedConv
Check out the Ultimate DIY sticky in Tech
Old May 10, 2009 | 11:11 AM
Armedruby's Avatar
Armedruby
Did mine a drivers side a month or two ago from instructions on the DIY thread. Great, fairly easy do it yourself fix. Gotta love this forum.
Old May 10, 2009 | 01:55 PM
97C5owner's Avatar
97C5owner
Good scoop! I'm a victim of the rocking seat gremlin!! Annoying. Can't wait to fix it now. Thanks!!
How long did it take ya'll using the DIY thread??
Old May 10, 2009 | 03:50 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
When I removed my seats, (for insulation) there was no coinage. The previous owner was either anally clean, or broke! Rocking to be addressed this winter... thanks for the link.
Old May 11, 2009 | 01:57 AM
Jesse Asis's Avatar
Jesse Asis
To 97C5Owner, The first seat rail took approximately 40 mins., the next three rails took about 15 mins. each to remove and a few more minutes to repair and return. Bottom line, I started at 8am Mon. morning ended with all back to normal by 11am. I blew a fuse on the drivers seat, ???, I just unplugged the two connectors, why, don't know.... I did find 79 cents total under the seats so the owner of this vette was not **** (he was still cheap, I was hoping for a few bills or two....). Oh, I also found one french fry, McDonald, I could tell it was years old but still tasted like it was made yesterday, Naw, but now I stopped eating at Micky Ds since finding it.... Later guys, you guys are all great...
Old May 11, 2009 | 09:23 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Thanks for posting. Amazing that the fix is simply replacing worn out rubber with nylon washers. Imagine what a dealer would charge for this and the profit margin!
Old May 11, 2009 | 09:10 PM
Armedruby's Avatar
Armedruby
Seems like an 1 1/2 hrs for the drivers seat. Maybe a little longer. I stared at it a bit and checked pictures...etc.. Second seat would take 30 minutes maybe? Didn't need to do the passenger seat on mine. Probably should have just so that I wouldn't have to do it later. The rubber bushings in mine were in pieces.
Old May 13, 2009 | 03:44 AM
Jesse Asis's Avatar
Jesse Asis
Armedruby, I decided to do both, again if one is worn most likely the other will follow. I'm old school, if one headlight bulb burns out, I always replace both sides. They have a burn time and if installed together, most likely will burn out together. Doing both seats seemed like the best thing to do so I didn't have to start the wheel all over in a couple months or a year, get her done...Enjoy
Old May 20, 2009 | 09:38 AM
joe@zip's Avatar
joe@zip
Platinum Supporting Vendor
We have a new kit coming in for this problem as well. Here is the post from our Corvette Parts Blog:
Finally there is a solution to the annoying seat rocking in C5 Corvettes. Lucky for you it does not require purchasing a whole new seat track unit from GM, which would cost around $550 not including labor to install. In years past this would have been your only option once your Corvette’s Seat Tracks began rocking during acceleration or braking, but now Zip Corvette has a replacement seat track shim kit that will solve your problems and save you money.
Corvette Seat Track Shim Kit
The C5 Corvette Seat Track Shim Kit comes with 4 new self lubricating shims that replace the original shims, which often deteriorate and wear out over time. Installation of the new shims is not difficult and is easily accomplished with basic mechanical skills. Step-by-step instructions are included as well as 2 short arm stubby torx wrenches that are required for installation. These wrenches can rarely be purchased at local hardware stores and are often only available in complete tool kits.
Purchase online at Zip Corvette Parts
Read more Corvette Parts news...
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
Old May 20, 2009 | 02:26 PM
nextime's Avatar
nextime
Interesting. Having my dealer fix the issue under the extended warranty. Hopefully I will get a spare set of seat tracks out of the deal.
To Rocking and rolling C5 seats....
